TrueNAS 12.0-U8 NAS-114052 - Still seeing errors with alert checkboxes after supposed fix
testfire10
Could you folks please check this and see if I'm missing something? Basically, this was a bug I submitted and was supposed to be fixed in this update,
"On TrueNAS Core (12.0-U7), on the Alert Services page:
I have alert emails setup for each alert level (Emergency, Alert, Error, etc. - I've made one for all of them), because I was troubleshooting/testing some of the alert features. I noticed that when I un-check the box for Critical (for example), the system does not actually un-check the critical box, but the Emergency Box. It appears to have this behavior when attempting to un-check any alert level lower than the most severe alert in the list - it will always refuse to uncheck the one you want, but instead un-check the most severe alert."
If you go into the alert services page, you should see checkboxes for any alerts you have. When you click/unclick one of them (if you have more than one), does that checkmark change for you? Or is it another one?
