TrueCommand Stuck At Login After Reboot
tomkhoo
Hi Community,
I have fresh installed TrueCommand running in docker with Ubuntu, at first it is running and everything fined. However after reboot, TrueCommand stuck at login page. Seems like not responding, even I tried to keyin wrong password system also not prompt me alert instead keep spinning forever.
Best Regards,
Tom
Did you set up Docker to survive a reboot? What is the docker run command you used to start the TrueCommand container?
tomkhoo
Hi Basil,
No, how to configure Docker to survive a reboot? I'm using sudo dockerd & command.
