I don't know what to do anymore. I have a jail in which Plex is installed, and I used to update it like this:
Then something happened with jails between 11.0 and 11.1 or something, so then I'd always get a package version warning:
I read around about this a while back and learned I needed to obtain the updates for the correct version I was running, and found I had to run this:
Which in turn, meant I needed to specify the package repository with version 1101505. So I used to do that and it would update. Now, however, it's just always saying the packages are up to date when freshports is showing I am definitely not up to date:
You can see that it's showing version 1.13.5.XXXX is the latest version.
FreshPorts, however, is showing that version 1.13.7.XXXX is the latest version:
https://www.freshports.org/search.p...leted&start=1&casesensitivity=caseinsensitive
I'm kind of stuck here and looking for some guidance. I would like to update my jails, but with whatever happened in the updates to FreeNAS that screwed up my jails is frustrating. I was able to run this procedure the last time there was a plex update, but now it's no longer working.
pkg update pkg upgrade
root@plex_media_server:/ # pkg update Updating FreeBSD repository catalogue... [plex_media_server] Fetching meta.txz: 100% 944 B 0.9kB/s 00:01 [plex_media_server] Fetching packagesite.txz: 100% 6 MiB 3.4MB/s 00:02 Processing entries: 0% Newer FreeBSD version for package peps: To ignore this error set IGNORE_OSVERSION=yes - package: 1004000 - running kernel: 1003000 Allow missmatch now?[Y/n]: n pkg: repository FreeBSD contains packages for wrong OS version: FreeBSD:10:amd64 Processing entries: 100% Unable to update repository FreeBSD Error updating repositories!
root@plex_media_server:/ # uname -KU 1101505 1003000
root@plex_media_server:~ # pkg -o OSVERSION=1101505 update Updating FreeBSD repository catalogue... FreeBSD repository is up to date. All repositories are up to date. root@plex_media_server:~ # pkg -o OSVERSION=1101505 search plexmediaserver-plexpass plexmediaserver-plexpass-1.13.5.5291 Plex Media Server component
