KrisStaf88
- Dec 10, 2017
I use :
FreeNAS-9.10.2-U6 (561f0d7a1).
FreeBSD 10.3-STABLE (FreeNAS.amd64)
I login as a root by putty.
I want to have Gogs or Gitlab on my freeNas, but installation ins't a simple, as other plugins in jail. Both gogs or gitlab needs to update package-s to install additional stuff like: memcached and redis by command:
Of course, above inst possible, because there is no packages. So I'm tying to update a pkg and I got (logs bellow).
Could you help me with it ?
Bellow are other stuff, that I tried do, and may help to find a solution.
I use :
[root@freenas] /# /usr/sbin/pkg install -y memcached redis
[root@freenas] /# /usr/sbin/pkg update -f
Updating FreeBSD repository catalogue...
Fetching meta.txz: 100% 944 B 0.9kB/s 00:01
Fetching packagesite.txz: 100% 6 MiB 1.5MB/s 00:04
Processing entries: 100%
FreeBSD repository update completed. 27001 packages processed.
Updating local repository catalogue...
pkg: Repository local load error: access repo file(/var/db/pkg/repo-local.sqlite) failed: No such file or directory
pkg: file:///usr/ports/packages/meta.txz: No such file or directory
repository local has no meta file, using default settings
pkg: file:///usr/ports/packages/packagesite.txz: No such file or directory
Unable to update repository local
Error updating repositories!
[root@freenas] ~# /usr/sbin/pkg update
pkg: Repository FreeBSD load error: access repo file(/var/db/pkg/repo-FreeBSD.sqlite) failed: No such file or directory
Fetching packagesite.txz: 100% 6 MiB 2.0MB/s 00:03
[root@freenas] /var/db/pkg# ls
./ FreeBSD.meta local.sqlite
../ local.meta repo-FreeBSD.sqlite
[root@freenas] /# grep url /etc/pkg/FreeBSD.conf
url: "pkg+http://pkg.FreeBSD.org/${ABI}/quarterly",
