BlairEL
- Feb 2, 2016
Hi all,
I've banging my head on this for ages and just not making any progress, I hope someone can help. I am following the steps to setup PIA inside a transmission jail, I do not get any errors, but my public IP remains the same, rather than a PIA IP.
I am following this guide LINK
Here is the output
root@transmission_1:/ # tail /var/log/messages
Apr 11 19:48:06 transmission_1 transmission-daemon[10681]: UDP Failed to set reeive buffer: requested 4194304, got 42080 (tr-udp.c:84)
Apr 11 19:50:11 transmission_1 pkg: pkg upgraded: 1.10.1 -> 1.10.5
Apr 11 19:50:51 transmission_1 pkg: wget upgraded: 1.19.1 -> 1.19.4_2
Apr 11 19:53:02 transmission_1 syslogd: kernel boot file is /boot/kernel/kernel
Apr 11 19:53:03 transmission_1 transmission-daemon[13486]: UDP Failed to set reeive buffer: No buffer space available (tr-udp.c:65)
Apr 11 19:53:03 transmission_1 transmission-daemon[13486]: UDP Failed to set reeive buffer: requested 4194304, got 42080 (tr-udp.c:84)
Apr 11 19:55:52 transmission_1 syslogd: exiting on signal 15
Apr 11 19:55:55 transmission_1 syslogd: kernel boot file is /boot/kernel/kernel
Apr 11 19:55:56 transmission_1 transmission-daemon[16149]: UDP Failed to set reeive buffer: No buffer space available (tr-udp.c:65)
Apr 11 19:55:56 transmission_1 transmission-daemon[16149]: UDP Failed to set reeive buffer: requested 4194304, got 42080 (tr-udp.c:84)
and here is my open vpn .conf file
client
dev tun
proto udp
remote us-california.privateinternetaccess.com 1196
resolv-retry infinite
nobind
persist-key
persist-tun
cipher aes-128-cbc
auth sha1
tls-client
remote-cert-tls server
auth-user-pass
comp-lzo
verb 1
reneg-sec 0
crl-verify crl.rsa.2048.pem
any advice would be appreciated.
Here is the output
client
dev tun
proto udp
nobind
persist-key
persist-tun
cipher aes-128-cbc
auth sha1
tls-client
auth-user-pass
comp-lzo
verb 1
reneg-sec 0
