maybe /usr/pbi/transmission-amd64/etc/transmission/settings.json doesn't exist? unfortunately you may need to redo your transmission settings in transmission plugin menu from the left panel of the freenas interface.
hmm, actually you might want to try restarting the jail transmission is running in. might be something with the Python interface that control the plugin being to be restarted.
Tried restarting jail and nothing, also the sad part is the plugin isn't showing up on the left panel any longer.
Hmm... I'll have to see if the settings file got nuked somehow.
If you restart transmission it will generate this.
sysrc 'transmission_enable=YES'
service transmission start
Ideally you could find a way to get the python interface to work so you could more easily start the plugin. I tested the upgrade myself and it worked after restarting the jail, but it did wipe my config and I had to redo my options.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
