 - Oct 29, 2016
I went back to ealier posts and I see that you do have jail and household. so I'm thinking that's your current thing to sort out.
i'm look at my own systems to see how one you access a .system without it being mounted automatically to /var/db/system
alternatives to trying to mount it directly, you might be able to try either:
exporting and reimporting both, but in the other order
moving the system dataset via system > system dataset might automagically find your wayward config files. have never tried that. it should preseve everything as the separate configs are separate datasets
