After a power outage, my volume won't import on boot.
I had to use a fresh install just to get it to boot to the GUI. When I re-import my old config, it stops mid-boot to a
Starts importing, hits an error and reboots. I see a "restart on panic" in the log during boot.
I'm not sure what to try next. I would appreciate any help.
DB>
prompt. zpool import
id: 12881666984181511294 state: ONLINE status: The pool was last accessed by another system. action: The pool can be imported using its name or numeric identifier and the '-f' flag. see: http://illumos.org/msg/ZFS-8000-EY config: Volume1 ONLINE raidz1-0 ONLINE gptid/2c768e52-0c28-11e7-94d3-3085a9ee45b4 ONLINE gptid/a3fe838c-3f34-11e7-a2d9-3085a9ee45b4 ONLINE gptid/1ae02e97-c0e4-11e6-a3e2-3085a9ee45b4 ONLINE gptid/4cff6522-067b-11e7-94d3-3085a9ee45b4 ONLINE gptid/0ef523f5-ea8e-11e6-9baa-3085a9ee45b4 ONLINE
zpool import Volume1
cannot import 'Volume1': pool may be in use from other system, it was last accessed by (hostid: 0x5dabc964) on Fri Aug 17 07:00:16 2018 use '-f' to import anyway
zpool import -f Volume1
and zpool import -F -f Volume1
zpool status
pool: freenas-boot state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
camcontrol devlist
<ST10000VN0004-1ZD101 SC60> at scbus0 target 0 lun 0 (pass0,ada0) <ST10000VN0004-1ZD101 SC60> at scbus1 target 0 lun 0 (pass1,ada1) <ST10000VN0004-1ZD101 SC60> at scbus2 target 0 lun 0 (pass2,ada2) <ST10000VN0004-1ZD101 SC60> at scbus3 target 0 lun 0 (pass3,ada3) <ST10000VN0004-1ZD101 SC60> at scbus4 target 0 lun 0 (pass4,ada4) <SanDisk Cruzer Fit 1.27> at scbus6 target 0 lun 0 (pass5,da0)
