Yet another import failure of an encrypted pool (I read the other posts I swear).
USB boot device failed, rebuilding in VMware VM (PCI Passthrough). All hardware is the same with the addition of a hard drive, installed ESXi 6.5 U2, installed FreeNAS VM.
Unable to import encrypted volume from the GUI. It does show all 4 disks, I provide the key (not the recovery), and passphase. Error: The following disks failed to attach: gptid/5ade1c3d-b3af-11e7-805d-ac1f6b1a7c12, gptid/5b816450-b3af-11e7-805d-ac1f6b1a7c12, gptid/5c21dc85-b3af-11e7-805d-ac1f6b1a7c12, gptid/5a37a31d-b3af-11e7-805d-ac1f6b1a7c12
zpool import and zpool import -f return to cursor (no action).
Hardware:
Supermicro SYS-5028D-TN4T
8 CPUs (Cores) Intel(R) Xeon(R) CPU D-1541 @ 2.10GHz
16GB RAM
4 x 10TB Ironwolf Drives
128GB SSD (newly added for ESXi install, VM datastore)
VM:
2 CPU
8GB RAM
16GB vDisk
PCI Passthrough of the SATA controller
zpool status:
geli list:
glabel list:
camcontrol devlist:
I have high confidence in the encryption key, recovery key, and passphase. Hard drives were fine before the failure as well.
Any ideas?
Hardware:
16GB RAM
VM:
2 CPU
8GB RAM
16GB vDisk
zpool status:
root@freenas:~ # zpool status pool: freenas-boot state: ONLINE scan: none requested config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 da0p2 ONLINE 0 0 0 errors: No known data errors
geli list:
root@freenas:~ # geli list Geom name: mirror/swap0.eli State: ACTIVE EncryptionAlgorithm: AES-XTS KeyLength: 128 Crypto: hardware Version: 7 Flags: ONETIME KeysAllocated: 4 KeysTotal: 4 Providers: 1. Name: mirror/swap0.eli Mediasize: 2147483648 (2.0G) Sectorsize: 512 Mode: r1w1e0 Consumers: 1. Name: mirror/swap0 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 Geom name: mirror/swap1.eli State: ACTIVE EncryptionAlgorithm: AES-XTS KeyLength: 128 Crypto: hardware Version: 7 Flags: ONETIME KeysAllocated: 4 KeysTotal: 4 Providers: 1. Name: mirror/swap1.eli Mediasize: 2147483648 (2.0G) Sectorsize: 512 Mode: r1w1e0 Consumers: 1. Name: mirror/swap1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1
glabel list:
root@freenas:~ # glabel list Geom name: da0p1 Providers: 1. Name: gptid/5ebab0c1-5946-11e8-86cb-000c291587b3 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 20480 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 1024 length: 524288 index: 0 Consumers: 1. Name: da0p1 Mediasize: 524288 (512K) Sectorsize: 512 Stripesize: 0 Stripeoffset: 20480 Mode: r0w0e0 Geom name: ada1p2 Providers: 1. Name: gptid/5ade1c3d-b3af-11e7-805d-ac1f6b1a7c12 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 19528679248 length: 9998683774976 index: 0 Consumers: 1. Name: ada1p2 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada2p2 Providers: 1. Name: gptid/5b816450-b3af-11e7-805d-ac1f6b1a7c12 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 19528679248 length: 9998683774976 index: 0 Consumers: 1. Name: ada2p2 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada3p2 Providers: 1. Name: gptid/5c21dc85-b3af-11e7-805d-ac1f6b1a7c12 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 19528679248 length: 9998683774976 index: 0 Consumers: 1. Name: ada3p2 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada4p2 Providers: 1. Name: gptid/5a37a31d-b3af-11e7-805d-ac1f6b1a7c12 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 secoffset: 0 offset: 0 seclength: 19528679248 length: 9998683774976 index: 0 Consumers: 1. Name: ada4p2 Mediasize: 9998683774976 (9.1T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0
camcontrol devlist:
root@freenas:~ # camcontrol devlist <VMware Virtual disk 2.0> at scbus2 target 0 lun 0 (pass0,da0) <NECVMWar VMware SATA CD00 1.00> at scbus3 target 0 lun 0 (cd0,pass1) <SuperMicro SSD SOB20R> at scbus33 target 0 lun 0 (pass2,ada0) <ST10000VN0004-1ZD101 SC60> at scbus34 target 0 lun 0 (pass3,ada1) <ST10000VN0004-1ZD101 SC60> at scbus35 target 0 lun 0 (pass4,ada2) <ST10000VN0004-1ZD101 SC60> at scbus36 target 0 lun 0 (pass5,ada3) <ST10000VN0004-1ZD101 SC60> at scbus37 target 0 lun 0 (pass6,ada4)
Any ideas?
