"The web interface could not be accessed"
Medi
Good morning. I'm setting up a NAS for work, I decided to use TrueNAS since it seemed like the best option. When I finish installing TrueNAS Core, no IP appears. I get the message:
"Please check network configuration"
The board is a Gigabyte B760M DS3H DDR4, and the network card is Realtek® 2.5GbE LAN chip (2.5 Gbps/1 Gbps/100 Mbps).
Any idea how I can make it work for me?
Thank you so much.
That hardware is in no way acceptable for any sort of professional use as a NAS. Your immediate symptoms are just a reflection of that fact.
Do not endanger your work by half-assing your IT infrastructure.
Medi
Thanks for the response. I will have to put a network card in the PCI Express slot for it to work. Is there any recommended card to place?
Thank you
