Stux
- Jun 2, 2016
That's good, because it would disable the BMC's V in iKVM, turning it into an iKM.
Could use SoL ;)
Of course. I'm planning to move to SoL as much as possible, by the way, it's just more elegant.Could use SoL ;)
True.Could use SoL ;)
Of course. You're heavily encouraged to keep backups of your config file, which can then be easily uploaded to a new install.(this is posible i presume?)
Is USB 3.0 (finally) officially supported in v11?Of course. You're heavily encouraged to keep backups of your config file, which can then be easily uploaded to a new install.
You are asking this for boot drives? If so would the speed difference matter so much for something that is hardly used after the machine has booted up? and a machine that is supposed to stay up 24/7?Is USB 3.0 (finally) officially supported in v11?
Has been since 9.10.Is USB 3.0 (finally) officially supported in v11?
Slightly slower overall but 64gb good for extra swap space
5. Cheap SSD.So suggestions ? 1 2 3 or 4 ?
5. Cheap SSD.
since i have only 8 sata ports what shal i do for boot
Write the drive serial number on a label on the face of the drive so that you can see it when it's in the case, it'll make it SO much easier to find the failing drive when the time comes.
That would be correct as I JUST read in another post - with dd.Oh good tip but with the drive cage's i bought won't freenas be able to make that drive blink ? (its how it used to work on qnap so sorry if i am saying something stupid here)
Multiple ways to solve that problem, how you go about it is up to you.hmmmm
