freenas version: 9
hi folks,
i'm pretty new to FreeNAS (or at least: i haven't got much experience). right now, i have a faulty drive, so i wanna do everything right.
i have a raid z2 with 8 drives. one of them is faulty right now. first of all: in the documentation, it says that you can see the resilvering status when calling
2) parallelly to the resilvering process, i probably can do a long SMART test on the faulty drive without making the mess worse, right?
3) if the SMART test is ok, i'd like to re-attach the drive to the raid z as every drive has got a "bad moment". how can i do that? first, i'll probably wait until the resilvering is done completely. and then i just type in
it would be great if you helped me out :)
cheers,
benni
hi folks,
zpool status. but there, i only see a scrub, no resilvering. 1) is that the same in this case? or how can i see the resilvering status? (please note that i have version 9 of FreeNAS).Code:
state: DEGRADED status: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Replace the faulted device, or use 'zpool clear' to mark the device repaired. scan: scrub in progress since Sun Nov 19 12:47:17 2017 2.06T scanned out of 16.3T at 478M/s, 8h41m to go 0 repaired, 12.60% done
zpool clear and everything is back to normal?it would be great if you helped me out :)
cheers,
benni
