I've set up my FreeNAS system and am burning in disks. While I wait, I'm planning the next steps for the installation and configuration. I'd like to use full disk encryption with AES-NI. The docu mentions that "encrypted volumes will not be displayed in the System dataset pool drop-down menu.".
What does this mean exactly? That an encrypted volume is not available as a location for the system dataset? Or is this a UI limitation and can be done via CLI?
If I only plan on creating one volume with all my disks, what options do I have for storing the system dataset? Where else do you keep the system dataset? FreeNAS is installed on a USB stick and somewhere else in the forums it was suggested not to put the system dataset on USB due to frequent writes.
