pro lamer
- Feb 16, 2018
Hi!
I am planning to have a mirror of 6TB HDDs for user data plus a pre-backup pool plus two spare SATA ports for external disks backup. I am planning to encrypt my data. Boot planned: mirrored pendrives/sd cards.
I've read a bit about risk related to encrypting and I am not very happy :/
Would I gain any way if my system dataset would be not encrypted (but instead having the HDDs sliced) in case of the encrypted pool failure? (comparing to having the system dataset together with the encrypted data and no slicing - EDIT: oops, I've learned it might not be possible - I'll read more to check if I can learn it by myself)
In other words: I am considering an alternative, also not recommended, solution (alternative to storing the system dataset together with the rest of the encrypted data, if it's still possible in current FreeNAS version) :
Which of them is less problematic/dangerous/risky/troublesome...?
I am assuming I need the system dataset somewhere else than the boot pendrives to avoid quick wear...
And I prefer not to have more HDDs yet/so far/for now - until my data needs grow...
slice both the HDDs into two slices each and dedicate the smaller slices pair to a pool holding only/mainly the system dataset and the bigger slices pair to an encrypted storage pool...create a pool using partitions, then import it in the GUI. I'm hesitant to give more detail, because that might imply I think this a good idea.
