Syncthing Management page gets redirected
dadiuc
Newbie
Hi guys,
I'm on FreeNAS-11.2-U2.1 with the latest updates to this day.
I have a recently installed jail of Syncthing(version 2 of jails, with iocage)
This used to work since the reboot after the update(yesterday) .
Today I stopped it to add some mount points to it. Then I started it again with no error.
When I open the management page, it redirects me to what it thinks is the FreeNAS login page (FreeNAS is on 192.168.1.150).
http://192.168.1.7/syncthing -> changes to -> http://192.168.1.7/ui/sessions/signin
So I try to investigate:
I log on to the jail (no.6) : jexec 6 csh
ps -aux
shows syncthing and nginx are running:
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND
root 6305 0.0 0.0 6412 2380 - IsJ 17:24 0:00.00 /usr/sbin/syslogd -c -ss
syncthing 6345 0.0 0.0 6388 2072 - IsJ 17:24 0:00.00 daemon: /usr/local/bin/syncthing[6346] (daemon)
syncthing 6346 0.0 0.6 118512 49704 - IJ 17:24 0:00.29 /usr/local/bin/syncthing -home=/usr/local/etc/syncthing -logfile=/var/log/syncthing.log -no-browser
root 6379 0.0 0.0 6464 2396 - IsJ 17:24 0:00.00 /usr/sbin/cron -J 15 -s
syncthing 6405 0.0 0.6 118512 50268 - INJ 17:24 0:02.05 /usr/local/bin/syncthing -home=/usr/local/etc/syncthing -logfile=/var/log/syncthing.log -no-browser
root 7106 0.0 0.1 11608 7052 - IsJ 17:33 0:00.00 nginx: master process /usr/local/sbin/nginx
www 7107 0.0 0.1 11608 7528 - SJ 17:33 0:00.00 nginx: worker process (nginx)
root 7090 0.0 0.0 7488 3900 1 SJ 17:33 0:00.03 csh
Syncthing is also working as I can see it with my local client as being active.
Nginx service is also working and has no error when starting/stoping/restarting.
The jail's log is also error free:
ELF ldconfig path: /lib /usr/lib /usr/lib/compat /usr/local/lib
32-bit compatibility ldconfig path: /usr/lib32
Setting hostname: syncthing.
Creating and/or trimming log files.
Starting syslogd.
Clearing /tmp (X related).
Starting syncthing.
Updating motd:.
Performing sanity check on nginx configuration:
Starting nginx.
Starting cron.
Strange thing is it worked before I stopped it to add the mountpoint and now it doesn't!? (Deleted the mount-point, restarted the jail, rebooted NAS to no avail)
I have other jails that work and behave OK.
Does anyone have a clue what the issue is or point me in the right direction?
Thanks in advance
flamie666
Newbie
Hello guys,
I can confirm this, is happening to me too.
I can't find anything about this in the logs.
flamie666
Newbie
Not yet. It may has something to do with nginx as reverse proxy and the initial config. I'll dig more into it.
mrteaiot
Member
I just start using and installing Syncthing on my new FreeNAS 11.2 UI. I got it to work with mounting points. Then I stop the service and add new mounting point. I restart the Syncthing service with no issue. But when I click the Management, it open up new windows with pages refused/error nothing show up. Any idea why? Seem to be the same problem.
himuraken
Newbie
Chiming in to report the exact same behaviour here on 11.3-U1, fresh build/load of both FN and the Syncthing plugin/jail.
