intelligence
- Jun 2, 2015
Hey!
Just like topic title, I've noticed that my newly built FreeNAS box becomes unresponsive. Last night I had troubles around 2 am, and tonight I'm seeing same issue around 12 am.
I'm tunneling into my box via:
ssh -D 15443 -p 52739 me@xxx.duckdns.org
What I noticed both times is that when I enable the proxy connection in my browser I immediately get tons of:
channel 4: open failed: administratively prohibited: open failed spam, with different channel numbers.
If I try to access any jails or the dashboard I simply get ERR_SOCKS_CONNECTION_FAILED.
I also noticed that the Transmission web ui becomes unresponsive when the proxy tunnel is enabled, but when I turn it off I can access it again via my duckdns subdomain.
Doing a ps aux reveals
Not sure about the top one, but cpu usage seems crazy?
Doing a "w" tells me
Here's the content of /var/log/messages:
http://pastie.org/private/rrlcclal30qt1eboeproa
Last night it just started working again, it has yet to happen this time around..
USER PID %CPU %MEM VSZ RSS TT STAT STARTED TIME COMMAND root 11 796.8 0.0 0 128 ?? RL 5:55PM 2965:55.26 [idle] 921 10707 10.6 0.2 174088 57208 ?? SsJ 5:56PM 32:24.07 /usr/pbi/transmission-amd64/bin/transmission-daemon -g /var/db/transmission -x /var/run/transmission/d root 12 2.7 0.0 0 480 ?? WL 5:55PM 17:33.26 [intr] root 814 0.5 0.0 0 16 ?? DL 5:55PM 3:43.10 [ipmi0: kcs] root 0 0.4 0.0 0 12288 ?? DLs 5:55PM 25:48.81 [kernel] root 1 0.0 0.0 6276 584 ?? ILs 5:55PM 0:00.02 /sbin/init -- root 2 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [crypto] root 3 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [crypto returns] root 4 0.0 0.0 0 64 ?? DL 5:55PM 0:00.00 [ctl] root 5 0.0 0.0 0 224 ?? DL 5:55PM 1:03.58 [zfskern] root 6 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [xpt_thrd] root 7 0.0 0.0 0 16 ?? DL 5:55PM 0:00.01 [pagedaemon] root 8 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [vmdaemon] root 9 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [pagezero] root 10 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [audit] root 13 0.0 0.0 0 128 ?? DL 5:55PM 0:00.00 [ng_queue] root 14 0.0 0.0 0 48 ?? DL 5:55PM 1:58.73 [geom] root 15 0.0 0.0 0 16 ?? DL 5:55PM 0:21.23 [yarrow] root 16 0.0 0.0 0 128 ?? DL 5:55PM 0:00.78 [usb] root 17 0.0 0.0 0 16 ?? DL 5:55PM 0:00.03 [bufdaemon] root 18 0.0 0.0 0 16 ?? DL 5:55PM 0:11.00 [syncer] root 19 0.0 0.0 0 16 ?? DL 5:55PM 0:00.05 [vnlru] root 20 0.0 0.0 0 16 ?? DL 5:55PM 0:00.13 [softdepflush] root 215 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [g_mp_kt] root 746 0.0 0.0 0 16 ?? DL 5:55PM 0:00.00 [ftcleanup] root 965 0.0 0.0 12048 1852 ?? Is 5:55PM 0:00.00 dhclient: igb0 [priv] (dhclient) _dhcp 1014 0.0 0.0 12048 1888 ?? Is 5:55PM 0:00.01 dhclient: igb0 (dhclient) root 1188 0.0 0.0 14228 1740 ?? Is 5:56PM 0:00.00 /usr/sbin/moused -p /dev/ums0 -t auto -I /var/run/moused.ums0.pid root 1494 0.0 0.0 6276 1276 ?? Is 5:56PM 0:00.01 /sbin/devd root 1868 0.0 0.0 33744 3168 ?? I 5:56PM 0:00.00 /usr/local/sbin/syslog-ng -p /var/run/syslog.pid root 1869 0.0 0.0 116696 11020 ?? Is 5:56PM 0:00.40 /usr/local/sbin/syslog-ng -p /var/run/syslog.pid root 1872 0.0 0.0 12048 8024 ?? Ss 5:56PM 0:00.07 /usr/sbin/watchdogd root 1901 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] ada3p1] root 1902 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] ada3p1] root 1903 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] ada3p1] root 1904 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] ada3p1] root 1905 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] ada3p1] root 1906 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] ada3p1] root 1907 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] ada3p1] root 1908 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] ada3p1] root 1910 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] ada0p1] root 1911 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] ada0p1] root 1912 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] ada0p1] root 1913 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] ada0p1] root 1914 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] ada0p1] root 1915 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] ada0p1] root 1916 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] ada0p1] root 1917 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] ada0p1] root 1919 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] ada1p1] root 1920 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] ada1p1] root 1921 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] ada1p1] root 1922 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] ada1p1] root 1923 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] ada1p1] root 1924 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] ada1p1] root 1925 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] ada1p1] root 1926 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] ada1p1] root 1928 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] ada2p1] root 1929 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] ada2p1] root 1930 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] ada2p1] root 1931 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] ada2p1] root 1932 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] ada2p1] root 1933 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] ada2p1] root 1934 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] ada2p1] root 1935 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] ada2p1] root 1937 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] da0p1] root 1938 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] da0p1] root 1939 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] da0p1] root 1940 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] da0p1] root 1941 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] da0p1] root 1942 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] da0p1] root 1943 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] da0p1] root 1944 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] da0p1] root 1946 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] da1p1] root 1947 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] da1p1] root 1948 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] da1p1] root 1949 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] da1p1] root 1950 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] da1p1] root 1951 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] da1p1] root 1952 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] da1p1] root 1953 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] da1p1] root 1955 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[0] da2p1] root 1956 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[1] da2p1] root 1957 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[2] da2p1] root 1958 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[3] da2p1] root 1959 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[4] da2p1] root 1960 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[5] da2p1] root 1961 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[6] da2p1] root 1962 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [g_eli[7] da2p1] root 2063 0.0 0.0 0 16 ?? DL 5:56PM 0:00.00 [Timer] root 2422 0.0 0.0 22224 4008 ?? Ss 5:56PM 0:00.39 /usr/sbin/ntpd -g -c /etc/ntp.conf -p /var/run/ntpd.pid -f /var/db/ntpd.drift root 2689 0.0 0.0 28096 4416 ?? I 5:56PM 0:00.11 /usr/local/sbin/smartd -i 1800 -c /usr/local/etc/smartd.conf -p /var/run/smartd.pid root 2896 0.0 0.0 26348 5224 ?? Is 5:56PM 0:00.00 nginx: master process /usr/local/sbin/nginx nobody 2916 0.0 0.0 9912 2248 ?? Is 5:56PM 0:00.02 /usr/local/sbin/mdnsd root 2920 0.0 0.0 39408 5084 ?? I 5:56PM 0:00.32 /usr/local/sbin/netatalk root 2935 0.0 0.0 91828 9632 ?? I 5:56PM 0:00.23 /usr/local/sbin/afpd -d -F /usr/local/etc/afp.conf root 2936 0.0 0.0 34884 4876 ?? I 5:56PM 0:00.00 /usr/local/sbin/cnid_metad -d -F /usr/local/etc/afp.conf root 2987 0.0 0.4 303764 147416 ?? I 5:56PM 0:02.00 /usr/local/bin/python -R /usr/local/www/freenasUI/manage.py runfcgi method=threaded host=127.0.0.1 por root 2991 0.0 0.3 215000 85644 ?? I 5:56PM 0:21.61 python: alertd (python2.7) messagebus 2999 0.0 0.0 14308 2328 ?? Is 5:56PM 0:00.00 /usr/local/bin/dbus-daemon --system root 3034 0.0 0.1 182720 30444 ?? Ss 5:56PM 0:31.87 /usr/local/sbin/collectd root 3191 0.0 0.0 49220 5544 ?? Is 5:56PM 0:00.00 /usr/sbin/sshd root 3283 0.0 0.0 12048 1680 ?? Is 5:56PM 0:00.00 daemon: /usr/local/libexec/nas/register_mdns.py[3284] (daemon) root 3284 0.0 0.2 179892 61616 ?? I 5:56PM 0:00.69 /usr/local/bin/python /usr/local/libexec/nas/register_mdns.py (python2.7) root 4829 0.0 0.0 12080 1868 ?? SsJ 5:56PM 0:00.02 /usr/sbin/syslogd -s 816 4885 0.0 0.4 362208 122792 ?? SJ 5:56PM 0:45.03 /usr/pbi/couchpotato-amd64/bin/python2.7 /usr/pbi/couchpotato-amd64/share/couchpotato/CouchPotatoServe root 4892 0.0 0.0 14184 1860 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 5132 0.0 0.1 133376 41752 ?? IJ 5:56PM 0:02.68 /usr/pbi/couchpotato-amd64/bin/python2.7 /usr/pbi/couchpotato-amd64/control.py start 192.168.1.4 12348 root 5997 0.0 0.0 12080 1868 ?? SsJ 5:56PM 0:00.02 /usr/sbin/syslogd -s 972 6047 0.0 0.4 333804 137500 ?? IsJ 5:56PM 0:07.91 /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Plex_Media_Server (Plex Media Server) root 6055 0.0 0.0 14184 1860 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 6295 0.0 0.1 133032 41252 ?? IJ 5:56PM 0:02.80 /usr/pbi/plexmediaserver-amd64/bin/python2.7 /usr/pbi/plexmediaserver-amd64/control.py start 192.168.1 972 6720 0.0 0.6 431500 196560 ?? SNJ 5:56PM 0:20.93 Plex Plug-in [com.plexapp.system] /usr/pbi/plexmediaserver-amd64/share/plexmediaserver/Resources/Plug- root 7175 0.0 0.0 12080 1868 ?? SsJ 5:56PM 0:00.02 /usr/sbin/syslogd -s root 7228 0.0 0.0 14184 1860 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 7469 0.0 0.1 133312 41352 ?? IJ 5:56PM 0:02.82 /usr/pbi/sickbeard-amd64/bin/python2.7 /usr/pbi/sickbeard-amd64/control.py start 192.168.1.5 12349 root 8334 0.0 0.0 12080 1868 ?? SsJ 5:56PM 0:00.02 /usr/sbin/syslogd -s 816 8392 0.0 0.6 447376 209504 ?? SJ 5:56PM 2:26.27 /usr/pbi/sickrage-amd64/bin/python2.7 /usr/pbi/sickrage-amd64/share/sickrage/SickRage/SickBeard.py --d root 8400 0.0 0.0 14184 1868 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 8640 0.0 0.1 133376 42096 ?? IJ 5:56PM 0:02.75 /usr/pbi/sickrage-amd64/bin/python2.7 /usr/pbi/sickrage-amd64/control.py start 192.168.1.7 12351 root 9499 0.0 0.0 12080 1868 ?? IsJ 5:56PM 0:00.02 /usr/sbin/syslogd -s 816 9549 0.0 0.4 256524 126616 ?? SsJ 5:56PM 3:44.17 /usr/pbi/sonarr-amd64/bin/mono /usr/pbi/sonarr-amd64/share/sonarr/NzbDrone/NzbDrone.exe --data=/var/db root 9557 0.0 0.0 14184 1860 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 9797 0.0 0.1 139964 40860 ?? IJ 5:56PM 0:02.80 /usr/pbi/sonarr-amd64/bin/python2.7 /usr/pbi/sonarr-amd64/control.py start 192.168.1.6 12350 root 10672 0.0 0.0 12080 1868 ?? IsJ 5:56PM 0:00.03 /usr/sbin/syslogd -s root 10736 0.0 0.0 14184 1860 ?? IsJ 5:56PM 0:00.02 /usr/sbin/cron -s root 10976 0.0 0.1 133032 41304 ?? IJ 5:56PM 0:04.16 /usr/pbi/transmission-amd64/bin/python2.7 /usr/pbi/transmission-amd64/control.py start 192.168.1.2 123 root 12505 0.0 0.0 14140 1920 ?? Is 5:56PM 0:00.02 /usr/sbin/cron -s root 12692 0.0 0.0 45000 4436 ?? I 5:57PM 0:00.01 /sbin/zfsd -d zfsd www 22164 0.0 0.0 26348 5644 ?? I 12:00AM 0:00.00 nginx: worker process (nginx) root 22271 0.0 0.0 71916 6140 ?? Is 12:02AM 0:00.01 sshd: int [priv] (sshd) int 22273 0.0 0.0 71916 6140 ?? S 12:02AM 0:00.05 sshd: int@pts/0 (sshd) root 22633 0.0 0.0 3776 1540 ?? IN 12:16AM 0:00.00 sleep 300 root 2708 0.0 0.0 18596 3284 v0- IN 5:56PM 0:00.04 /bin/sh /usr/local/sbin/pbid root 12684 0.0 0.2 171316 62436 v0 Is+ 5:57PM 0:00.70 python /etc/netcli (python2.7) root 12685 0.0 0.0 12048 1732 v1 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv1 root 12686 0.0 0.0 12048 1732 v2 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv2 root 12687 0.0 0.0 12048 1732 v3 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv3 root 12688 0.0 0.0 12048 1732 v4 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv4 root 12689 0.0 0.0 12048 1732 v5 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv5 root 12690 0.0 0.0 12048 1732 v6 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv6 root 12691 0.0 0.0 12048 1732 v7 Is+ 5:57PM 0:00.00 /usr/libexec/getty Pc ttyv7 int 22274 0.0 0.0 12296 2968 0 Is 12:02AM 0:00.01 -bash (bash) root 22461 0.0 0.0 68180 5668 0 I 12:09AM 0:00.01 sudo su root 22476 0.0 0.0 45280 2388 0 I 12:10AM 0:00.00 su root 22477 0.0 0.0 17524 3868 0 S 12:10AM 0:00.02 _su (csh) root 22652 0.0 0.0 16256 2040 0 R+ 12:17AM 0:00.00 ps aux
12:17AM up 6:23, 1 user, load averages: 0.05, 0.16, 0.21
