datamining
- Feb 28, 2013
Hey everyone!
before we start....
i decided to throw my old stuff away and refresh my "NAS-System" .. so for now i will just keep my case (supermicro 933) and my drives (6x 2TB WD). FreeNAS installation on a USB-Pen (Kingston).
I´ll checked the forum etc. and I got the following set-up:
Mainboard: 1x SUPERMICRO X10SLM-F
CPU: 1x Intel Core i5-4570 with 4x 3.20GHz
CPU: 1x Intel Xeon E3-1230 v3 "Haswell"
RAM: 4x 8192MB Kingston DDR3 ECC KVR1333D3E9S/8G
Okay so what i want to do is to run ZFS with RAIDZ2and iSCSI for my VMware ESX cluster. The mainboard has six SATA-Ports (4x SATA3 and 2x SATA2), are these ports enough to run FreeNAS on ir should i go for an IBM ServeRAID 1015? I´m not sure how the system will perform .. but what I need is enough performance for about 40 virtual server..
Would the performance be better if I use an additional 1015 or should I buy two of them to leave the onbaord stuff alone?
thanks a lot!
regards
miner
before we start....
looks like they have some problems with the 8GB modules
RAM: 2x 8GB Samsung ECC M391B1G73BH0-CK0Okay so what i want to do is to run ZFS with RAIDZ2and iSCSI for my VMware ESX cluster. The mainboard has six SATA-Ports (4x SATA3 and 2x SATA2), are these ports enough to run FreeNAS on ir should i go for an IBM ServeRAID 1015? I´m not sure how the system will perform .. but what I need is enough performance for about 40 virtual server..
thanks a lot!
regards
miner
