SOLVED! See below for my reply to my own issue.
OK. I had FreeNAS running for over a year and the current version is 9.10 something.
I started getting messages that my boot drive was over 80%.
I removed all other bootable instances but still ended up at 88%.
I had 2 16GB Sandisk usb drives (sticks) in a mirror configuration. Not sure why a single instance would take up 12GB of space but I decided I might as well upgrade the USB drives.
I bought 2 64GB Samsung USB drives.
I removed one of the existing 16GB USB drives and replaced it with one of the 64GB drives. HOWEVER, since these new drives are USB3.0 I went ahead and put the new drive in a USB3.0 slot (the others were in USB2.0 slots).
The resilver process was extremely slow, but seemed to work.
I repeated the exact same process once the resilvering was done with the other USB drive; including putting the new drive in a different slot for USB3.0.
The resilver process was just as slow, but seemed to work.
According to the GUI, everything looked hunky dory except for the fact that it was still only recognizing the 16GB still.
I went in to the terminal and discovered that the auto-resize was turned off for the boot drive so I turned it on.
I then told zfs to bring one of the drives in the mirrored pool online (per instructions I found on Google) and the pool was then recognized as 64GB (58GB actually).
Everything up to now seemed great. Until I rebooted the system.
Now I am stuck at this "Loading Operating System..." on the directly connected monitor.
My first thought was that there is a problem with my USB3.0 controller, making everything very slow. I waited for an hour but it was still stuck at this screen.
I rebooted the server and physically moved the two new USB drives to the original slots that the original USB drives were in and I am getting the same result.
Any help is very much appreciated!
