Strongly request to add buzzer alarm settings in TrueNAS
dktech
You're going to need to be much more specific about what you mean if you want a feature to be added.
Have you looked at the existing Alert systems and found that something isn't sufficient?
Have you looked at TrueCommand?
dktech
It may be that I am not clear. I am a Chinese user and I use Google Translate to post. What I want to say is if the system has a warning, can I use the motherboard buzzer to sound the warning? Hope this feature can be added. Thank you
