Why does TrueNAS Core have no buzzer alarm function?
dktech
Shouldn't the buzzer alarm be a basic function as a NAS system? Why has the TrueNAS team never considered it? It seems that there is no detailed tutorial in this regard, which is very unfriendly to novice users.
That would require the system is have a small piezo-electric speaker in the system.
I suspect the most of the systems offered by iXsystems don't have one, or if they do, it is only for BIOS boot beep codes.
dktech
In fact, ix, like many individual users, chooses supermicro motherboards more often. Supermicro motherboards already have buzzers, but they never use them.
I don't see why it would. A NAS operates on a network, and therefore is often--probably "usually"--remote from its users. So who would hear the buzzer going, under whatever circumstances you think that should happen?
dktech
Because I found that sometimes system alerts cannot be sent by email, and there are also many users who do not set up email notifications.
hear ya go! pun intended.
Seriously, it appears it has to be enabled in the kernel to use spkrtest command in CORE.
I wasn't able to find a tunable. Might have to be compiled in.
root@NAS-1[/boot]# spkrtest
You have no write access to /dev/speaker or the speaker device is
not enabled in kernel. Cannot play any melody! See spkr(4).
Perhaps submit a ticket requesting it be enabled.
I figured out how to make the speaker on my QNAP NAS running CORE to beep.
sh -c "echo -e '\a' > /dev/console"
#!/bin/sh
for ((i = 0; i < 20; i++));
        do
                sleep 1
        done
dktech
dktech
#!/bin/sh
        do
                sleep 1
        done
Excuse me, how should I use it?
And that is over the awful fan noise!
Patrick M. Hausen
Been there ...
dktech
Then can we make the buzzer sound when the TrueNAS sends out an alarm? I believe this feature is available in the TrueNAS MINI.
ChrisRJ
Even for home users I think an audible alarm instead of an email is a really bad idea. Do you have a scenario where there is an advantage?
As to the email setup: If someone is unable or unwilling to do that little bit of work, they don't care about their data anyway.
dktech
I don't think this feature is redundant for data security.
AlexGG
The buzzer, integrated into the machine itself, is less likely to become disconnected or fail in some other manner than an email server.
So if someone sets up an email notification, and then a year after, the email fails to arrive (because of a mail server change or because appropriate ports got blocked on the firewall during the year), the buzzer is still likely to work.
Seriously, is anyone going to notice a tiny built in piezo-electric speaker in a server closet full of fans whirring at full speed?
I think you need one of these. :smile:
