If your jails vnet_default_interface is set to "auto", it will create the bridge with the interface that has got the default route. Which should be igb1. You should definitely never plug in two interfaces into the same LAN unless you know very well what you are doing.
You can check if the bridge is really configured the right way with ifconfig
on the command line.
if you had explicitly configured re0 for your jails you should change that to "auto" or "igb1" if you have only one flat LAN. If there are multiple networks, possibly VLANs etc. things are a bit more complicated. But first check if the jails really use igb1.
Thanks for taking the time to reply.
I quickly learned having two nics on the same lan was a bad bad idea. RE0 was disconnected shortly after the i350 install, but still the problem persisted till someone suggested I completely disable the onboard nic. This resulted in everything working for about 8 hrs.
Here is my ifconfig, from the Truenas shell, with the i350 completely removed from the box. The onboard RE0 is enabled, and all three jails are working. All three jails have their vnet default interface set to "auto", looks like it grabs the RE0 nic. Under network properties for the jail, all three jails have the line vnet0:bridge0.
root@freenas:~ # ifconfig
re0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=82099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,LINKSTATE>
ether 2c:f0:5d:62:43:a2
inet 192.168.1.133 netmask 0xffffff00 broadcast 192.168.1.255
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
nd6 options=1<PERFORMNUD>
options=680003<RXCSUM,TXCSUM,LINKSTATE,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x2
groups: lo
pflog0: flags=0<> metric 0 mtu 33160
groups: pflog
ether 02:eb:43:21:f3:00
maxage 20 holdcnt 6 proto stp-rstp maxaddr 2000 timeout 1200
member: vnet0.6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: vnet0.4 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 2000
member: vnet0.1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 5 priority 128 path cost 2000
member: re0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
groups: bridge
vnet0.1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: Plex as nic: epair0b
options=8<VLAN_MTU>
ether 2e:f0:5d:31:41:ea
hwaddr 02:1b:5f:3f:d3:0a
groups: epair
status: active
vnet0.4: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: zoneminder as nic: epair0b
options=8<VLAN_MTU>
ether 2e:f0:5d:21:a9:30
hwaddr 02:a9:f8:78:e4:0a
groups: epair
status: active
vnet0.6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
description: associated with jail: nzb as nic: epair0b
options=8<VLAN_MTU>
Here is ifconfig's output when RE0 is disabled completely, the i350 is installed, an ethernet is connected to IGB3.
igb0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=e507bb<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,TSO4,TSO6,LRO,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6,TXCSUM_IPV6>
ether a0:36:9f:08:01:38
status: no carrier
igb1: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether a0:36:9f:08:01:39
status: no carrier
igb2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
ether a0:36:9f:08:01:3a
status: no carrier
igb3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=a500b9<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,JUMBO_MTU,VLAN_HWCSUM,VLAN_HWFILTER,VLAN_HWTSO,RXCSUM_IPV6>
ether a0:36:9f:08:01:3b
status: active
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
groups: lo
groups: pflog
member: vnet0.3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 10 priority 128 path cost 2000
member: vnet0.2 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 9 priority 128 path cost 2000
ifmaxaddr 0 port 8 priority 128 path cost 2000
member: igb3 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 4 priority 128 path cost 20000
groups: bridge
options=8<VLAN_MTU>
hwaddr 02:2f:a0:b8:14:0a
groups: epair
status: active
vnet0.2: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 2e:f0:5d:21:a9:29
hwaddr 02:2c:20:14:5e:0a
groups: epair
status: active
vnet0.3: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
To my inexperienced eyes, everything looks fine. But the jails act strangely, sometimes I can access them, sometimes I can't. If I restart the jails, I can access them from my laptop, but not my android phone both of which are on wifi. The router box can individually ping each jail no problem, while the devices that cannot reach the web gui cannot ping them.
I'm genuinely baffled by this working once in awhile situation.
