Hi, I hope you all are well. My new TrueNas install (TrueNAS-12.0-U3) is not utilizing the 1000basetx speed of the motherboard (Intel DH67BL) onboard NIC and the installed Intel i350-t4. I did search the forum, and I've tried some of the solutions I found with no luck. Full disclaimer, I am a noob : )
Because my motherboard is a LGA1155 socket, I had to mask the B5 & B6 pins of the i350-t4 nic in order for the system to boot. I have this same card with masked pins in a pfsense box running at 1000basetx not problem. The ifconfig shows the media status as (Ethernet autoselect (100baseTX <full-duplex>)
I would appreciate any help solving this issue. Please let me know if there are any code reports I should post, in order to help solving this issue.
Thank you!
Hardware:
Motherboard: Intel DH67BL
NIC: i350-t4
switch: unifi 24 ports fully managed (Gigabit Ethernet Ports)
Thank you!
Hardware:
NIC: i350-t4
