Stopping Badblocks? TMUX Error
Kris Heslop
Newbie here, I was attempting to test a replacement for 4TB WD Red HD that is showing bad sectors, while I was at it I started the non-destructive read test on 3 other hard disks.
I used SSH and logged in but I made a mistake and entered Cntrl-b" instead of Cntrl-B" when I started Badblocks instance 2, 3, and 4...
So I had four instances running, and wanted to stop them, but can only stop the last one.
Any suggestions on how to proceed and or stop these?
Can I reboot and not do any damage? Anything else I should know?
Terminal window shows:
Last login: Mon Jan 9 07:32:49 2017 from tmux(11490).%3
FreeBSD 10.3-STABLE (FreeNAS.amd64) #0 r295946+07c41cd(9.10-STABLE): Wed Nov 9 00:19:25 UTC 2016
FreeNAS (c) 2009-2016, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
[root@HeslopNAS] ~# badblocks -b 4096 -ws /dev/ada4
Testing with pattern 0xaa: set_o_direct: Inappropriate ioctl for device
"badblocks"^R0.51% done, 2:07 elapsed. (0/0/0 errors)
"badblocks^[[B^R0.60% done, 2:31 elapsed. (0/0/0 errors)
"badblocks^[[badblocks -b 4096 -ns /ada/ada^R0.77% done, 3:12 elapsed. (0/0/0 er
"badblocks^[[badblocks -b 4096 -ns /ada/a^R0.77% done, 3:13 elapsed. (0/0/0 erro
"badblocks^[[badblocks -b 4096 -ns /a^R0.78% done, 3:14 elapsed. (0/0/0 errors)
"badblocks^[[badblocks -b 4096 -ns /dev/ada3 0.87% done, 3:37 elapsed. (0/0/0 e
26.97% done, 1:58:25 elapsed. (0/0/0 errors)
[root@HeslopNAS] ~# badblocks -b 4096 -ns /dev/ada0
Checking for bad blocks (non-destructive read-write test)
Testing with random pattern: set_o_direct: Inappropriate ioctl for device
19.24% done, 1:53:42 elapsed. (0/0/0 errors)
5651895 done, 9:31 elapsed. (0/0/0 errors)
7.01% done, 1:53:01 elapsed. (1/0/0 errors)
Kris Heslop
Since I could not find any solutions on-line, here or on other forums: I went ahead and rebooted, which did not appear to hurt anything.
Since I had run one pass (not the normal 4 passes) the day before which stopped on the second pass with no identifiable reason, I went ahead and replaced the failing drive, which generated the following (pasted below) during the resilver process.
Now in reading that manual, I am left at a loss of what to next to remove the failed drive and use the replacement drive.
Since it shows multiple items (see attached file) and not sure which to take off-line. But then again, when I looked yesterday iI missed where it waid to take the first disk off-line (but this was a striped array, not Zx.) SO now I am not certain which I should "Remove" I replaced ADA1 with ADA4...Now I shows "ADA1p2" and "replacing2" Should I remove both of those?
As to the items below, I think they have to do with the failing drive, which when I started said it had one file (with data corruption,) and then when completed came back and said I had 6 files with problems (each different from the initial file reported.) I have gotten emails referring to s SMART failure count going to 13 and the checksum reports 12 problems...
SMP: AP CPU #2 Launched!
Timecounter "TSC-low" frequency 1696108426 Hz quality 1000
vboxdrv: fAsync=0 offMin=0x1ec offMax=0x10e4
epair0a: promiscuous mode enabled
arp: 192.168.2.2 moved from 02:ff:20:00:05:0a to 6c:0b:84:3e:2d:94 on epair0b
GEOM_ELI: Device ada1p1.eli destroyed.
GEOM_ELI: Detached ada1p1.eli on last close.
GEOM_ELI: Device ada4p1.eli created.
GEOM_ELI: Encryption: AES-XTS 128
GEOM_ELI: Crypto: hardware
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 58 c3 b1 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): CAM status: ATA Status Error
(ada1:ahcich1:0:0:0): ATA status: 41 (DRDY ERR), error: 40 (UNC )
(ada1:ahcich1:0:0:0): RES: 41 40 e0 c3 b1 40 02 00 00 00 00
(ada1:ahcich1:0:0:0): Retrying command
(ada1:ahcich1:0:0:0): Error 5, Retries exhausted
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 28 d1 b1 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): RES: 41 40 58 d1 b1 40 02 00 00 00 00
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 88 de b1 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): RES: 41 40 d0 de b1 40 02 00 00 00 00
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 48 eb b1 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): RES: 41 40 40 ec b1 40 02 00 00 00 00
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 00 18 ea 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): RES: 41 40 30 18 ea 40 02 00 00 00 00
(ada1:ahcich1:0:0:0): READ_FPDMA_QUEUED. ACB: 60 00 48 ed b1 40 02 00 00 01 00 00
(ada1:ahcich1:0:0:0): RES: 41 40 b8 ed b1 40 02 00 00 00 00
-- End of security output --
D
dlavigne
Guest
If it's a stripe, you have no redundancy and have lost that data.
If that is the case, why not reformat with the known good drives into a pool that provides redundancy?
