SSH Jail issue
The Apprentice
Hello all,
I installed a new jail in Freenas to run my web server...
As there isn't any PBI for webserver yet, i had to do it all manually.
So far i managed to update the port tree and set the host name OK.
I tied to active ssh and set
sshd_enable="YES"
when i first started
service sshd start i di get the following:
webserver# service sshd start
SELECT ssh_host_key from services_ssh: not found
SELECT ssh_host_key_pub from services_ssh: not found
SELECT ssh_host_dsa_key from services_ssh: not found
SELECT ssh_host_dsa_key_pub from services_ssh: not found
SELECT ssh_host_ecdsa_key from services_ssh: not found
SELECT ssh_host_ecdsa_key_pub from services_ssh: not found
SELECT ssh_host_rsa_key from services_ssh: not found
SELECT ssh_host_rsa_key_pub from services_ssh: not found
Generating public/private rsa1 key pair.
Your identification has been saved in /etc/ssh/ssh_host_key.
Your public key has been saved in /etc/ssh/ssh_host_key.pub.
The key fingerprint is:
fb:7e:a2:54:5e:3f:e7:46:9b:e5:b8:af:6c:2f:d7:28 root@webserver
The key's randomart image is:
+--[RSA1 1024]----+
|        S . .    |
|         + . .  o|
|        o .   o=*|
|       . .. E.=*=|
|        .ooo o+O+|
Generating public/private dsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_dsa_key.
Your public key has been saved in /etc/ssh/ssh_host_dsa_key.pub.
56:af:d1:7b:00:9f:f7:66:9d:14:93:f2:9b:1a:c5:a8 root@webserver
+--[ DSA 1024]----+
|          o  . + |
|         . = .= o|
|        S . *..= |
|       .   o.+o.=|
|          .E...+=|
|             .oo |
Generating public/private rsa key pair.
Your identification has been saved in /etc/ssh/ssh_host_rsa_key.
Your public key has been saved in /etc/ssh/ssh_host_rsa_key.pub.
8e:3c:4a:9e:25:5d:9c:79:12:c4:47:81:3c:07:82:5d root@webserver
+--[ RSA 2048]----+
|     o.+E+o.     |
|    . .o= o      |
|        S .      |
|     o + o       |
|    o * .        |
|   o = .         |
Starting sshd.
As i was unable to login with my user i did
service sshd restart and got
Stopping sshd.
Starting sshd.
but everithing is there
webserver# cd /etc/ssh/
webserver# ls
moduli                  ssh_host_dsa_key        ssh_host_key            ssh_host_rsa_key        sshd_config
ssh_config              ssh_host_dsa_key.pub    ssh_host_key.pub        ssh_host_rsa_key.pub
Has anyone know why?
Thank you all
Fred
joeschmuck
Old Man
This may be a stupid question but why don't you just SSH into the FreeNAS and then get into the jail, the same way I assume you added the web server into the jail. Okay, let me ask you this since I'm making an assumption that you added the web server into the jail, did you add the web server to the jail? If so, how did you access the jail to do this? I'm asking so I know you have done it properly, not because I don't know how.
-Joe
The Apprentice
I did Ssh to my freenas box n then jexexc to my jail.
Them done all port update, username.. Then installed Nginx
The Apprentice
Sorry for the long delay in replying, i have been away..
No i haven't created a user in the Jail, will try that and post the update:)
Thank you
- - - Updated - - -
Ok.. I just added a user and put it in the wheel group....
As soon as i do
sshd restart
i get the same message
webserver# service sshd restart
Stopping sshd.
Starting sshd.
J
James
Guest
How did you install the jail? Does reinstalling the jail PBI fix the issue?
