The Apprentice
- Aug 10, 2012
Hello all,
I installed a new jail in Freenas to run my web server...
As there isn't any PBI for webserver yet, i had to do it all manually.
So far i managed to update the port tree and set the host name OK.
I tied to active ssh and set
when i first started
service sshd start i di get the following:
As i was unable to login with my user i did
service sshd restart and got
but everithing is there
Has anyone know why?
Thank you all
Fred
sshd_enable="YES"
webserver# service sshd start SELECT ssh_host_key from services_ssh: not found SELECT ssh_host_key_pub from services_ssh: not found SELECT ssh_host_dsa_key from services_ssh: not found SELECT ssh_host_dsa_key_pub from services_ssh: not found SELECT ssh_host_ecdsa_key from services_ssh: not found SELECT ssh_host_ecdsa_key_pub from services_ssh: not found SELECT ssh_host_rsa_key from services_ssh: not found SELECT ssh_host_rsa_key_pub from services_ssh: not found Generating public/private rsa1 key pair. Your identification has been saved in /etc/ssh/ssh_host_key. Your public key has been saved in /etc/ssh/ssh_host_key.pub. The key fingerprint is: fb:7e:a2:54:5e:3f:e7:46:9b:e5:b8:af:6c:2f:d7:28 root@webserver The key's randomart image is: +--[RSA1 1024]----+ | | | | | | | | | S . . | | + . . o| | o . o=*| | . .. E.=*=| | .ooo o+O+| +-----------------+ Generating public/private dsa key pair. Your identification has been saved in /etc/ssh/ssh_host_dsa_key. Your public key has been saved in /etc/ssh/ssh_host_dsa_key.pub. The key fingerprint is: 56:af:d1:7b:00:9f:f7:66:9d:14:93:f2:9b:1a:c5:a8 root@webserver The key's randomart image is: +--[ DSA 1024]----+ | | | .| | o . + | | . = .= o| | S . *..= | | . o.+o.=| | .E...+=| | .oo | | . | +-----------------+ Generating public/private rsa key pair. Your identification has been saved in /etc/ssh/ssh_host_rsa_key. Your public key has been saved in /etc/ssh/ssh_host_rsa_key.pub. The key fingerprint is: 8e:3c:4a:9e:25:5d:9c:79:12:c4:47:81:3c:07:82:5d root@webserver The key's randomart image is: +--[ RSA 2048]----+ | o.+E+o. | | . .o= o | | .+ | | . + | | S . | | o + o | | o * . | | o = . | | + | +-----------------+ Starting sshd.
Stopping sshd. SELECT ssh_host_key from services_ssh: not found SELECT ssh_host_key_pub from services_ssh: not found SELECT ssh_host_dsa_key from services_ssh: not found SELECT ssh_host_dsa_key_pub from services_ssh: not found SELECT ssh_host_ecdsa_key from services_ssh: not found SELECT ssh_host_ecdsa_key_pub from services_ssh: not found SELECT ssh_host_rsa_key from services_ssh: not found SELECT ssh_host_rsa_key_pub from services_ssh: not found Starting sshd.
webserver# cd /etc/ssh/ webserver# ls moduli ssh_host_dsa_key ssh_host_key ssh_host_rsa_key sshd_config ssh_config ssh_host_dsa_key.pub ssh_host_key.pub ssh_host_rsa_key.pub
Thank you all
Fred
