SOLVED SSD - One or more devices has experienced an error
Phe0nix
I had a 6 year old Sandisk flashdrive and it began to have issues loading FreeNas, so i made a new backup of my config file
and installed two identical SSD drives and reinstalled with the latest FreeNas and choose the option to install
using UEFI however it wouldn't boot to the drive after the install so i formated them and repeated the installation
and choose BIOS then uploaded my config file and all is great other than i'm getting the same error.
Since the drives are new and i had to repeat the install i'm thinking it was related to my install issues ?
Does that sound more likely than one of my new SSD drives are on their way out ?
Chris Moore
We have seen, over the years, that certain brands and models of SSD do not work reliably with ZFS / FreeNAS.
Were the new SSDs the same brand / model as the six year old one? What model drive are we talking about here?
also have you recently upgraded from 11.0?
Phe0nix
Sorry guys, I didn’t think I was going to get a response.
Both SSD drives are New , I recently removed my 6 yr old USB boot device. I just decided to start over with 11.2-U7 and run mirror SSD’s instead of a single USB.
If anyone knows of any SSD’s that work reliably with ZFS please let me know.
Okay your problem is related to this bug report https://jira.ixsystems.com/browse/NAS-100276 you can run those SSD's by disabling trim which is what I have done or you can return them and buy some that do not have Silicon Motion controllers in them.
Phe0nix
Thank you Cobrakiller58 , I think I’d rather keep them and disable trim. I appreciate your time and effort you put into my issue.
