One or more devices has experienced an unrecoverable error
runevn
My Freenas machine got this error.
CRITICAL
Pool storagepool state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected..
Wed, 11 Mar 2020 06:31:39 PM (Europe/Copenhagen)
When I scroll down the console it see these events.
Mar 11 18:31:20 nas     (da4:mps0:0:19:0): READ(10). CDB: 28 00 1e a9 ba e8 00 00 40 00 length 32768 SMID 1006 terminated ioc 804b loginfo 31080000 scsi 0 state 0 xfer 0
Mar 11 18:31:20 nas     (da4:mps0:0:19:0): READ(10). CDB: 28 00 1e a9 bb 28 00 00 40 00 length 32768 SMID 238 terminated ioc 804b loginfo 31080000 scsi 0 state 0 xfer 0
Mar 11 18:31:20 nas (da4:mps0:0:19:0): CAM status: CCB request completed with an error
Mar 11 18:31:20 nas (da4:mps0:0:19:0): Retrying command
Mar 11 18:31:20 nas (da4:mps0:0:19:0): WRITE(16). CDB: 8a 00 00 00 00 02 5b 0a 08 a8 00 00 00 08 00 00
Mar 11 18:31:20 nas (da4:mps0:0:19:0): CAM status: SCSI Status Error
Mar 11 18:31:20 nas (da4:mps0:0:19:0): SCSI status: Check Condition
Mar 11 18:31:20 nas (da4:mps0:0:19:0): SCSI sense: ILLEGAL REQUEST asc:21,0 (Logical block address out of range)
Mar 11 18:31:20 nas (da4:mps0:0:19:0): Info: 0x25b0a08a8
Mar 11 18:31:20 nas (da4:mps0:0:19:0): Error 22, Unretryable error
Mar 11 18:31:20 nas GEOM_ELI: g_eli_write_done() failed (error=22) gptid/5a699763-aee3-11e9-9fbd-000c29ee2069.eli[WRITE(offset=5177919688704, length=4096)]
Mar 11 18:31:20 nas ZFS: vdev state changed, pool_guid=5350473571605863105 vdev_guid=10886824740025151227
I don't have that much experience in reading these event logs so can you help me understanding what is going on?
I can see that it is probably the da4 drive that has an issue. However, I replaced this drive 1 month ago because the last drive also threw different error messages.
What should I do? And please let me know if you need more information.
Thanks
My setup is:
Dell r720xd
Running FreeNAS-11.3-U1 as a VM on Exsi 6.5 with LSI2008 run in passthrough
The drive is a WD-Red 6TB
You need to share the output of your SMART data for da4 (assuming you have scheduled SMART tests running)
smartctl -a /dev/da4
runevn
Thanks for your quick relpy, sretalla,
Here is the output
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p6 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/da4/: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
nas% sudo smartctl -a /dev/da4
Model Family:     Western Digital Red
Device Model:     WDC WD60EFRX-68MYMN1
Serial Number:    WD-WX11DC4FK7S7
LU WWN Device Id: 5 0014ee 2b63fd931
Firmware Version: 82.00A82
User Capacity:    6,001,175,126,016 bytes [6.00 TB]
Rotation Rate:    5700 rpm
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Mar 12 11:00:47 2020 CET
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)    Offline data collection activity
                    was never started.
Self-test execution status:      (   0)    The previous self-test routine completed
                    been run.
data collection:         ( 5204) seconds.
capabilities:              (0x7b) SMART execute Offline immediate.
                    command.
                    Self-test supported.
SMART capabilities:            (0x0003)    Saves SMART data before entering
                    power-saving mode.
Error logging capability:        (0x01)    Error logging supported.
Short self-test routine
recommended polling time:      (   2) minutes.
Extended self-test routine
recommended polling time:      ( 705) minutes.
Conveyance self-test routine
recommended polling time:      (   5) minutes.
SCT capabilities:            (0x303d)    SCT Status supported.
                    SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   212   199   021    Pre-fail  Always       -       8383
  4 Start_Stop_Count        0x0032   093   093   000    Old_age   Always       -       7224
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   045   045   000    Old_age   Always       -       40546
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       56
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       30
193 Load_Cycle_Count        0x0032   198   198   000    Old_age   Always       -       7529
194 Temperature_Celsius     0x0022   124   109   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 1
    CR = Command Register [HEX]
    FR = Features Register [HEX]
    ER = Error register [HEX]
    ST = Status register [HEX]
Error 1 occurred at disk power-on lifetime: 19436 hours (809 days + 20 hours)
  ER ST SC SN CL CH DH
  10 51 08 50 ad 21 e0  Error: IDNF at LBA = 0x0021ad50 = 2207056
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  ca 00 08 50 ad 21 e0 08  15d+22:43:30.484  WRITE DMA
  ca 00 60 f0 ac 21 e0 08  15d+22:43:30.467  WRITE DMA
  ca 00 08 78 c2 28 e0 08  15d+22:43:30.466  WRITE DMA
# 1  Short offline       Completed without error       00%     40529         -
# 2  Short offline       Completed without error       00%     40505         -
# 3  Short offline       Completed without error       00%     40481         -
# 4  Short offline       Completed without error       00%     40457         -
# 5  Short offline       Completed without error       00%     40433         -
# 6  Short offline       Completed without error       00%     40410         -
# 7  Short offline       Completed without error       00%     40386         -
# 8  Short offline       Completed without error       00%     40362         -
# 9  Short offline       Completed without error       00%     40338         -
#10  Short offline       Completed without error       00%     40314         -
#11  Extended offline    Completed without error       00%     40296         -
#12  Short offline       Completed without error       00%     40266         -
#13  Short offline       Completed without error       00%     40242         -
#14  Short offline       Completed without error       00%     40218         -
#15  Short offline       Completed without error       00%     40194         -
#16  Short offline       Completed without error       00%     40170         -
#17  Short offline       Completed without error       00%     40146         -
#18  Short offline       Completed without error       00%     40122         -
#19  Short offline       Completed without error       00%     40098         -
#20  Short offline       Completed without error       00%     40074         -
#21  Short offline       Completed without error       00%     40050         -
Thanks
So, your SMART data shows that this disk is healthy.
Chances are we're looking at either a cabling issue or something with the disk controller, that port in the backplane, the backplane itself or power.
Most to least likely causes (in my opinion from this distance):
Cabling
Backplane Port
Disk controller
Power
Entire Backplane
If you were having problems with the disk in that same position before, perhaps start with the cable leading to that disk (if it's separate).
