Chris Moore
- May 2, 2015
Are they still in warranty?I've created 2 more SSD paper weights
I had this error previously and had to reload FreeNAS; so I am going to do a fresh install one more time and see what is up. I guess I will do it via USB thumbdrive vice SSD which seems a bit antiquated.Are they still in warranty?
That might be the issue then...I was prepping them like you would prep the usb thumb drive with the iso file on them...I'm guessing this is a bad thing now.How are you preparing these SSDs? You shouldn't need to prep them at all other than to delete any existing partition table.
I will certainly do this in the future. I'm guessing it has to do with how the disks are accessed during the install process after I have created them as install media. An expensive lesson for sure.Create your usb thumb drive to make an install disk. Boot from the USB thumb drive to install to the SSD.
I do have a windows system, but no matter what tool I use, I can't reformat the drive due to write protection. It is the weirdest thing! Just another lesson with FreeNAS.You may be able to connect these SSDs to a Windows system (one at a time) to do a partition table wipe, after that, they may be working fine again. Let me know if you have a Windows system that you can give that a try with.
Have you tried the Microsoft command line tool named "diskpart"? It has worked with some of the problems that I have had.I do have a windows system, but no matter what tool I use, I can't reformat the drive due to write protection. It is the weirdest thing! Just another lesson with FreeNAS.
That's because Windows has limited GUI tools for this. Using diskpart in the command line to destroy all partition tables will do the trick.I do have a windows system, but no matter what tool I use, I can't reformat the drive due to write protection. It is the weirdest thing! Just another lesson with FreeNAS.
I followed the USB media creation steps in the install guide for a Mac. Installation starts fine, but the drive never shows up. I did get one SSD to show up, one time, but I think I booted from the USB by accident and ran the install from there. Anyway, I think it has to do with how the dd command copies the ISO over to the SSD. Whatever boot/install partition is created is write-protected and the installation program sees this and doesn't make the disk available for use to the system. It is the only thing that makes sense at this point. I'm going to get another SSD and use a USB as the install media and see if it is seen.Okey, this is interesting. What did you actually do to the SSDs??
I have not, but I will now as both you and Ericloewe have mentioned it.Have you tried the Microsoft command line tool named "diskpart"? It has worked with some of the problems that I have had.
Thanks! Appreciate it.That's because Windows has limited GUI tools for this. Using diskpart in the command line to destroy all partition tables will do the trick.
Of course, you can accomplish the same on FreeBSD.
Ninja'd.
It is because you can't treat a SSD like a USB drive. It was once the case with FreeNAS that you could put the installer on a USB stick, boot from that stick and then install FreeNAS to the same media that you just booted from, but that has not been true for a long time and, I suppose that the guide may need a bit of clarification on that topic. I have not looked at that part of the guide in probably 3 years or more.I followed the USB media creation steps in the install guide for a Mac. Installation starts fine, but the drive never shows up.
Don't do that yet. I think that you will be able to delete the partition on the SSD using theI'm going to get another SSD
clean
command from inside the diskpart
tool. clean
command doesn't care what is on the disk, it deletes the partition table. Just be careful you have the correct drive selected. Do you need help with that?No, I will be fine with it.Don't do that yet. I think that you will be able to delete the partition on the SSD using theclean
command from inside thediskpart
tool.
Theclean
Did you try this:Waiting on my buddy who gave me the original SSD to be done trying to fix it. He did run the clean command and it cleared partitions, but the drive was still write-protected and he couldn't format it.
