Hi All
New to forum so first post :) Used FreeBSD before but first time using FreeNAS.
I just started using FreeNAS 11 for my iSCSI shared storage for my vSphere 6.5 cluster. I have the following volumes configured in FreeNAS:
RAID 10 comprised of 4 Samsung SM863 480GB SSDs
RAID 1 comprised of 2 Samsung Pro 850 512GB SSDs
Single Western Digital 4TB SATA drive
Since I want to use VAAI with vSphere I created all the above as a zvol and ticked the sparse volume option.
It seems to be working well except I get these warning messages in the vmkernel.log on each of the ESXi hosts:
2017-11-08T21:56:44.833Z cpu15:66376)WARNING: ScsiDeviceIO: 2728: Space utilization on thin-provisioned device naa.6589cfc0000006f22a5c1eb41598028b exceeded configured threshold
This error seems to occur every 15min.
I also get these every 5min:
2017-11-08T21:56:44.833Z cpu15:66376)NMP: nmp_ThrottleLogForDevice:3617: Cmd 0x2a (0x439501012ec0, 129131) to dev "naa.6589cfc0000006f22a5c1eb41598028b" on path "vmhba64:C0:T1:L0" Failed: H:0x0 D:0x2 P:0x0 Valid sense data: 0x6 0x38 0x7. Act:NONE
If I run
I have tried changing the "Pool Available threshold" in the global configuration and/or changing it on each extent to a really low or high value or well as setting it to 50% or zero but I still keep getting these warnings despite having lots of free disk space in each volume in FreeNAS.
What am I missing here or doing wrong and how can I stop so many warnings being logged all the time?
Thanks for any help! :)
If I run
zfs list
I have loads of free space:Code:
NAME USED AVAIL REFER MOUNTPOINT freenas-boot 1.13G 114G 176K none freenas-boot/.system 28.7M 114G 176K legacy freenas-boot/.system/configs-2f1f44bcdd194541bc55d43e518f686d 764K 114G 764K legacy freenas-boot/.system/cores 636K 114G 636K legacy freenas-boot/.system/rrd-2f1f44bcdd194541bc55d43e518f686d 26.2M 114G 26.2M legacy freenas-boot/.system/samba4 204K 114G 204K legacy freenas-boot/.system/syslog-2f1f44bcdd194541bc55d43e518f686d 756K 114G 756K legacy freenas-boot/ROOT 1.09G 114G 136K none freenas-boot/ROOT/Initial-Install 8K 114G 1.08G legacy freenas-boot/ROOT/default 1.09G 114G 1.08G legacy freenas-boot/grub 7.82M 114G 7.82M legacy pro512 155G 302G 88K /mnt/pro512 pro512/iscsi 155G 302G 155G - sm863 254G 606G 88K /mnt/sm863 sm863/iscsi 254G 606G 254G - sm863/jails 88K 606G 88K /mnt/sm863/jails wd4tb 524G 3.00T 88K /mnt/wd4tb wd4tb/iscsi 524G 3.00T 524G -
