Chris230291
- Mar 21, 2012
Sickrage seems to be dead, people have been talking about SickChill but I had no luck with it.
Sonarr sucks... Untill you add Jackett... Then it works way better than Sickrage ever did... For me at least.
1. Install the Sonarr plugin
2. Inside the Sonarr jail run
3. Go to http://<jail IP>:9117
4. Add any indexers that you want and modify any URLs on ones that failed the "test" to proxy URLs that are not blocked in your region.
5. In Sonarr settings > indexers add a new "Torznab" custom indexer and fill out...
- Name (called mine "Jackett")
- URL "http://<jail IP>:9117"
- API Path "/torznab/all/api"
- API key (found in Jackett)
- I added "5000" to the catagories
DONE!
For me its working better than Sickrage ever did, finding episodes quickly and ones that Sickrage never found in all the years I had been running it.
Chris
pkg install -y jackett pkg upgrade sysrc jackett_enable=YES service jackett start
DONE!
Chris
