Some plugins show "off" while they are running normally
Sander Jansen
Hey,
I have been struggling with this for about 3 months now. I have 2 plugins show OFF (Plex and sabnzb) but the thing is, they are running just fine. At first i wanted to update them and the update failed and destroyed the whole jail. So i installed it to a clean one and set everything up as i had before. At first FreeNAS showed the plugin as ON as it should but after a reboot from FreeNAS it kept saying OFF for just those 2 plugins. The couch potato that i have running is not having this problem. it shows ON when it is on and OFF when it is off. but those other two allays show OFF... this also means that updating wont work.
I still have this problem even after updating to the latest version... does anyone know what the problem is? I mean it is not the end of the world as they ARE running but it would be nice to have the update thing working and the correct status.
EDIT:
here is most of the system specs:
Jailer
Not strong, but bad
System specs?
Sander Jansen
Interesting... yes there was:
Oct 23 21:14:41 freenas uwsgi: [freeadmin.navtree:562] Couldn't retrieve https://192.168.1.8/plugins/sabnzbd/2/_s/treemenu: HTTP Error 503: Service Unavailable
Oct 23 21:14:41 freenas uwsgi: [freeadmin.navtree:562] Couldn't retrieve https://192.168.1.8/plugins/plexmediaserver/3/_s/treemenu: HTTP Error 503: Service Unavailable
Oct 23 21:14:41 freenas kernel: arp: 192.168.1.8 moved from 02:ff:20:00:08:0a to d0:50:99:6f:e0:16 on epair1b
Oct 23 21:14:55 freenas uwsgi: [plugins.utils:88] Couldn't retrieve https://192.168.1.8/plugins/sabnzbd/2/_s/status: HTTP Error 503: Service Unavailable
Oct 23 21:14:56 freenas uwsgi: [plugins.utils:88] Couldn't retrieve https://192.168.1.8/plugins/plexmediaserver/3/_s/status: HTTP Error 503: Service Unavailable
Inxsible
@Sander Jansen Do you have Plex and SabNZBD both in the same jail? I ask because your logs show both on the same IP
Sander Jansen
Thy should have separate jails...? at least i installed them just like normal and thy show up normal? stupid thing is when i create a jail... the network settings are a mess... i need to go into the jail and do: "dhclient epair1b" and so on for all my jails... else thy dont get internet but could that also cause these problems? as i had the network problem since version 9.3 or something of freenas... it hasn't been a problem until like one of the latest updates of freenas...
Inxsible
Did you install the plugins from the Plugins menu in FreeNAS or did you create a standard jail and then install them via pkgupdate/pkgupgrade?
If you used the plugins, it should have automatically created a separate jail for every plugin that you installed unless you mucked with some settings.
Sander Jansen
I did it via the plugins page in freenas and ive never changed settings on where to create the jails... and yes from what i can see there all in deferent jails
Verzonden vanaf mijn iPhone met Tapatalk
zey
@Sander Jansen,
Have you resolved this issue? I recently starting experiencing the same issue after changing IPs. For me it also shows up off under the Installed Plugins tab. But if I go into Jails and restart the jail for that plugin it returns to on but a short while after it goes back to off and I have the following errors.
Nov 16 18:45:18 dobby kernel: ifa_maintain_loopback_route: deletion failed for interface lo0: 48
Nov 16 20:01:07 dobby uwsgi: [plugins.utils:88] Couldn't retrieve http://10.10.10.11/plugins/sabnzbd/1/_s/status: HTTP Error 503: Service Unavailable
Nov 16 20:01:07 dobby uwsgi: [plugins.utils:88] Couldn't retrieve http://10.10.10.11/plugins/transmission/2/_s/status: HTTP Error 503: Service Unavailable
Nov 16 20:01:07 dobby uwsgi: [plugins.utils:88] Couldn't retrieve http://10.10.10.11/plugins/emby/3/_s/status: HTTP Error 503: Service Unavailable
Nov 16 20:01:44 dobby uwsgi: [freeadmin.navtree:562] Couldn't retrieve http://10.10.10.11/plugins/emby/3/_s/treemenu: HTTP Error 503: Service Unavailable
Nov 16 20:01:44 dobby uwsgi: [freeadmin.navtree:562] Couldn't retrieve http://10.10.10.11/plugins/sabnzbd/1/_s/treemenu: HTTP Error 503: Service Unavailable
Nov 16 20:01:44 dobby uwsgi: [freeadmin.navtree:562] Couldn't retrieve http://10.10.10.11/plugins/transmission/2/_s/treemenu: HTTP Error 503: Service Unavailable
Sander Jansen
Sadly ive not been able to fix it... so far it seems to work fine (the jail) so i dont mind to much... but i do need to update my plex so ill be fiddeling with it soon again...
