[Solved] Qbittorrent default password/username does not work
Yaguznal
I installed the qbittorrent plugin without errors and the UI loads to the login screen but I tried to log in with anything from the default admin/adminadmin to newly created users and the default user qbittorrent but none work.
Did anyone get this to work?
ukinami
hi i has the same problem its the first time i use freenas can some one help me do resolve the porblem please ?
thanks
Jailer
Not strong, but bad
Try restarting the service and try again. service qbittorrent-nox restart I see the same behavior with a manual install on reboot that started several versions ago and restarting the service from the jail shell gets it going.
Jailer
Not strong, but bad
You can change it in the options in the web gui..
ukinami
Ok thakns now I have a new problem I can't access anymore to the floders I have share to windows lol
