Update [Oct 14, 2017]
As of FreeNAS-11-MASTER-201710140514, this issue seems to have been solved; confirmed on two different FreeNAS machines.
Mamdoh
Hi everyone,
I’m having a problem with SMB shares on MacOS Sierra. I can see the shares in “Finder”, but, when I click on them I get an error message like this:
I’m using some SMB shares that require authentication and some that don’t. Shares can be accessed from a Windows machine successfully, but not from two different Mac machines with different OS versions.
The shares can be accessed on my base-install nightlies [FreeNAS-11-MASTER-201705050409 (8273773)]
I tried this on 3 systems (1 physical and 2 virtual) running:
FreeNAS-11-MASTER-201710060521 [Nightlies]
FreeNAS-11-MASTER-201710070509 [Nightlies]
First, I noticed that the GUI for the “SMB Service” is missing the “Server Minimum Protocol” and “Server Maximum Protocol” options.
Second, the [global] section in “/usr/local/etc/smb4.conf” looks like this:
I noticed “/usr/local/etc/smb4.conf” doesn’t have the following parameter:
pid directory = /var/run/samba
I tried adding the missing line +/- a combination of the following to the “SMB Service” Auxiliary parameters:
server min protocol =
server max protocol =
But without any luck. Any ideas or solutions?
Thanks,
Mamdoh
N.B.: I know the deal with nightlies and how they are in a constant state of potential “brokenness”. :) I’m only providing a feedback, which is probably not as valuable as feedbacks on beta versions. But, might confirm to other users who are facing the same issue that it’s a software-specific, rather than machine/system-specific issue. Also, if it results in finding a solution, then that’s just an added value to the thread. I’m planning to clean-install a stable base-release in the near future.
Mamdoh
Hi everyone,
There was a problem connecting to the server “192.168.2.12”.
The share does not exist on the server. Please check the share name, and then try again.
[global] encrypt passwords = yes dns proxy = no strict locking = no oplocks = yes deadtime = 15 max log size = 51200 max open files = 171677 logging = file load printers = no printing = bsd printcap name = /dev/null disable spoolss = yes getwd cache = yes guest account = nobody map to guest = Bad User obey pam restrictions = yes ntlm auth = no directory name cache size = 0 kernel change notify = no panic action = /usr/local/libexec/samba/samba-backtrace nsupdate command = /usr/local/bin/samba-nsupdate -g server string = FreeNAS Server (Test) ea support = yes store dos attributes = yes lm announce = yes hostname lookups = yes time server = yes acl allow execute always = true dos filemode = yes multicast dns register = yes domain logons = no local master = yes idmap config *: backend = tdb idmap config *: range = 90000001-100000000 server role = standalone netbios name = FREENAS workgroup = MC_WORKGROUP security = user create mask = 0666 directory mask = 0777 client ntlmv2 auth = yes dos charset = CP437 unix charset = UTF-8 log level = 10
Thanks,
Mamdoh
