SMB service failed to start. HELP!
robbhimself
SMB will not start. Running 11.2 stable.
SMB worked fine on my first install but I screwed up permissions so bad somehow Freenas wouldnt even start so I reinstalled and reimported my pool.
I've reinstalled twice now with the same result.
Vanilla install smb toggles on. I reimport my pool and add a smb share, it loads for about 30 secs and says "call timeout" real small in the corner. After that SMB will not start. Even if i delete the smb share it still wont start.
I dont get it, im getting very frustrated.
Debug attached.
Edit: updated to 11.2-U2 issue persists
  • debug-gnarkill-20190219134624.tgz
anodos
Sambassador
Vanilla install smb toggles on. I reimport my pool and add a smb share, it loads for about 30 secs and says "call timeout" real small in the corner. After that SMB will not start. Even if i delete the smb share it still won't start.
I don't get it, im getting very frustrated.
Debug attached.
Can you PM me your configuration? System->general->save config. I don't need the "secret seed".
robbhimself
robbhimself
im convinced theres some permission issues going on causing all kinds of problems.
robbhimself
Post output of
getfacl /var/db/samba4
getfacl /var/db/samba4/private
getfacl /var/db/samba4/private/msg.sock
well thats not right....this is why I reinstalled before..
robbhimself
chown -R root:wheel /var/db/samba4
seems like its not taking affect
What jails/plugins are you using? Have you mounted any storage inside them?
im running a jail for sabnzbd and a jail/plugin for plex and ive set up mounts in both just fine. although in my sabnzbd mounts i would start having write issues to the disk if i tried to add a smb share and id have to re-chown the mount points
I setup permissions for sabnzbd and plex like this
service sabnzbd onestop
chown -R mediauser:mediauser /usr/local/sabnzbd
sysrc 'sabnzbd_user=mediauser'
chown -R mediauser:mediauser /usr/local/share/sabnzbdplus
chown -R mediauser:mediauser /var/run/sabnzbd
service sabnzbd start
also not sure if related or not, i have an nfs share mounted as root user on windows 10 and i cant open anything or write but i can view the files
anodos
Sambassador
Postmortem:
Issue was related to permissions on /var/db/samba4. Since that path is a symlink to /mnt/<pool>/.system/samba4, it was most likely affected by a permissions reset on the parent zpool. We do have some safeguards in place to prevent this from happening, but I will investigate if we need more.
Holt Andrei Tiberiu
Hello, same problem, fresh install of 11.3-U1
When i try to join the domain, it failes.
the /var/db/samba4 folder does not exist at all
any help?
server has fix IP.
i have mad a DNS entry on the domain PDC, and reverse dns entry
I can ping the PDC from freenas, and can ping the freenas from PDC
There is no time diffrence betwene the Freenas and PDC
ykhodo
any help?
server has fix IP.
same here
anodos
Sambassador
/var/db/samba4/ doesn't exist in 11.3. There is a separate thread about common problems with AD in 11.3-U1 and steps to preview fixes scheduled for U2.
