dgibson9503
- Jun 18, 2016
I just noticed this today, but not sure how long it has been going on. The smart service fails to start at boot and refuses to start manually. When I attempt to start manually I get the following in the log...
smartd[18651]: Unable to register device /dev/da1 (no Directive -d removable). Exiting.
da1 is one of the my USB boot drives and the first one within smartd.conf. Editing smartd.conf and deleting the lines referencing the USB drives, commenting the lines out or adding the "-d removable" directive to the lines allows smartd to start. Since smartd.conf is built at boot, these changed do not survive a reboot. I seems that
/etc/ix.rc.d/ix-smartd either shouldn't be adding these lines to smartd.conf or at least should be adding them differently.
Could anyone point me toward a more permanent fix for this? A forum search didn't seem to net anything similar.
It's also work noting that I just upgraded to 11.1-U1. Again, not sure if this was going on before OR if it started after the upgrade.
