Hello.
On my Dell server I have PERC H730P Adapter switch to HBA. The smartd fails to start at boot and manually. /usr/local/etc/smartd.conf is empty
I try turn off smart to da5 or add -d removable to S.M.A.R.T. extra options: - smartd fails to start.
Try this on FreeNAS-11.1-U5 and current test on FreeNAS-11.1-U6. Same result.
What can I do to repair smartd to generate /usr/local/etc/smartd.conf
When I add SATA disk, result is the same. /usr/local/etc/smartd.conf is empty
# camcontrol devlist <SEAGATE ST1200MM0099 ST31> at scbus15 target 0 lun 0 (pass0,da0) <SEAGATE ST1200MM0099 ST31> at scbus15 target 1 lun 0 (pass1,da1) <SEAGATE ST1200MM0099 ST31> at scbus15 target 2 lun 0 (pass2,da2) <SEAGATE ST1200MM0099 ST31> at scbus15 target 3 lun 0 (pass3,da3) <SEAGATE ST300MP0026 KT37> at scbus15 target 5 lun 0 (pass4,da4) <DP BP14G+ 4.26> at scbus15 target 32 lun 0 (ses0,pass5) <ADATA USB Flash Drive 1100> at scbus17 target 0 lun 0 (pass6,da5)
# /etc/ix.rc.d/ix-smartd start # /etc/ix.rc.d/ix-smartd status ix-smartd is not running.
# cat /var/log/messages | grep smart Sep 3 10:39:49 NAS01 smartd[2711]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries Sep 3 10:55:16 NAS01 smartd[5696]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries Sep 3 20:00:53 NAS01 smartd[39281]: Configuration file /usr/local/etc/smartd.conf parsed but has no entries
# cat /usr/local/etc/smartd.conf ################################################ # smartd.conf generated by /etc/ix.rc.d/ix-smartd ################################################
# smartctl -i /dev/da0 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST1200MM0099 Revision: ST31 Compliance: SPC-4 User Capacity: 1,200,243,695,616 bytes [1.20 TB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c500b82aeec7 Serial number: WFK0TS72 Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 3 19:40:01 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled # smartctl -i /dev/da1 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST1200MM0099 Revision: ST31 Compliance: SPC-4 User Capacity: 1,200,243,695,616 bytes [1.20 TB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c500b829ade3 Serial number: WFK0SYWH Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 3 19:40:22 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported # smartctl -i /dev/da2 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST1200MM0099 Revision: ST31 Compliance: SPC-4 User Capacity: 1,200,243,695,616 bytes [1.20 TB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c500b829f4e3 Serial number: WFK0TVEX Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 3 19:40:50 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported # smartctl -i /dev/da3 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST1200MM0099 Revision: ST31 Compliance: SPC-4 User Capacity: 1,200,243,695,616 bytes [1.20 TB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 10000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c500b82a214b Serial number: WFK0TTJQ Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 3 19:40:59 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported # smartctl -i /dev/da4 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST300MP0026 Revision: KT37 Compliance: SPC-4 User Capacity: 300,000,000,000 bytes [300 GB] Logical block size: 512 bytes Formatted with type 2 protection LU is fully provisioned Rotation Rate: 15000 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000c500b875d91b Serial number: WAE0Q7YK Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Mon Sep 3 19:41:03 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled
# camcontrol devlist <SEAGATE ST1200MM0099 ST31> at scbus15 target 0 lun 0 (pass0,da0) <SEAGATE ST1200MM0099 ST31> at scbus15 target 1 lun 0 (pass1,da1) <SEAGATE ST1200MM0099 ST31> at scbus15 target 2 lun 0 (pass2,da2) <SEAGATE ST1200MM0099 ST31> at scbus15 target 3 lun 0 (pass3,da3) <ATA WDC WD20EARX-00P AB51> at scbus15 target 5 lun 0 (pass4,da4) <DP BP14G+ 4.26> at scbus15 target 32 lun 0 (ses0,pass5) <ADATA USB Flash Drive 1100> at scbus17 target 0 lun 0 (pass6,da5)
# smartctl -i /dev/da4 smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build) Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Western Digital Green Device Model: WDC WD20EARX-00PASB0 Serial Number: WD-WCAZAF479174 LU WWN Device Id: 5 0014ee 207284631 Firmware Version: 51.0AB51 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS (minor revision not indicated) SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is: Tue Sep 4 09:34:41 2018 CEST SMART support is: Available - device has SMART capability. SMART support is: Enabled
