fahadshery
- Sep 29, 2017
Here is an example output of
Clearly the physical block size is
Here is
the diskinfo is showing the sector size to be 512 and My drives are of 4K? Am I doing it wrong?
I created the pools via GUI so I didn't mentioned any value of ashift=12.
smartctl
for my SSDs
and the HDD
smartctl --xall /dev/da10 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: SEAGATE Product: ST800FM0053 Revision: XGEC Compliance: SPC-4 User Capacity: 800,166,076,416 bytes [800 GB] Logical block size: 512 bytes Physical block size: 4096 bytes LB provisioning type: not reported [LBPME=1, LBPRZ=0] Rotation Rate: Solid State Device Form Factor: 2.5 inches Logical Unit id: 0x5000c50030135897 Serial number: Z3G014RB0000Z3G014RB Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Thu Dec 8 16:58:43 2022 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled Read Cache is: Enabled Writeback Cache is: Enabled
smartctl --xall /dev/da2 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Vendor: HGST Product: HUC101818CS4205 Revision: NE05 Compliance: SPC-4 User Capacity: 1,800,360,124,416 bytes [1.80 TB] Logical block size: 512 bytes Physical block size: 4096 bytes Formatted with type 2 protection 8 bytes of protection information per logical block LU is fully provisioned Rotation Rate: 10520 rpm Form Factor: 2.5 inches Logical Unit id: 0x5000cca02c655e70 Serial number: 08HTS73A Device type: disk Transport protocol: SAS (SPL-3) Local Time is: Thu Dec 8 16:59:37 2022 GMT SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Enabled Read Cache is: Enabled Writeback Cache is: Disabled
4K
but TrueNas created the logical block size of 512
bytes? Is that a problem? I thought both should be match???Here is
diskinfo
output:Code:
diskinfo -v /dev/da10 /dev/da10 512 # sectorsize 800166076416 # mediasize in bytes (745G) 1562824368 # mediasize in sectors 4096 # stripesize 0 # stripeoffset 97281 # Cylinders according to firmware. 255 # Heads according to firmware. 63 # Sectors according to firmware. SEAGATE ST800FM0053 # Disk descr. Z3G014RB0000Z3G014RB # Disk ident. mpr1 # Attachment Yes # TRIM/UNMAP support 0 # Rotation rate in RPM Not_Zoned # Zone Mode root@truenas[/mnt/ssd_fast10/postgres]# diskinfo -v /dev/da2 /dev/da2 512 # sectorsize 1800360124416 # mediasize in bytes (1.6T) 3516328368 # mediasize in sectors 4096 # stripesize 0 # stripeoffset 218881 # Cylinders according to firmware. 255 # Heads according to firmware. 63 # Sectors according to firmware. HGST HUC101818CS4205 # Disk descr. 08HTS73A # Disk ident. mpr0 # Attachment No # TRIM/UNMAP support 10520 # Rotation rate in RPM Not_Zoned # Zone Mode
