GBillR
- Jun 12, 2016
So this is behavior that I haven't seen before, and I am wondering if anyone else has.
A remote server alerted via email to failed SMART test for a particular drive. Relatively young drive (still within warranty period), but I've had drives fail before, so not completly unheard of obviously. I increased the SMART test interval to daily short and weekly long, and also increased the scrub periodicity to daily until I could get to the server to replace the drive. I pulled the drive last week and figured I would benchtest prior to RMA on my ubuntu 16.04 system via esata dock. Now, the SMART tests pass (short and long), and a -ws badblocks completed without error.
Has anyone ever seen a drive suddenly pass SMART tests after failing so many at the exact same spot on the drive? I would be suspicious of the sata cable, but the error occured at the exact same location each test (as I interpret the data anyway). FreeNAS never complained about the volume, only the SMART test failure count. The replacement drive (same cable) has had no issues. Maybe I don't understand what I am reading in the results. I don't see how I could trust the drive in production again... although it has been so long since I've had to RMA a drive, I'm not even sure this would meet their criteria. Any other testing I could do to try to stress the drive? Thoughts on the SMART data? The only abnormal info (beyond the failed tests) that I see in the SMART data is the line below. Based on my limited search, I'm not sure this is related, or if this is just a Ubuntu 16.04 bug.
Full readout here:
Thanks, -Bill
Read SMART Thresholds failed: scsi error badly formed scsi parameters
Full readout here:
Model Family: Western Digital Red
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-
LU WWN Device Id: 5 0014ee 20f4712a4
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Mon May 20 23:10:49 2019 EDT
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (25800) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 261) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 --- Pre-fail Always - 0
3 Spin_Up_Time 0x0027 174 173 --- Pre-fail Always - 4275
4 Start_Stop_Count 0x0032 100 100 --- Old_age Always - 18
5 Reallocated_Sector_Ct 0x0033 200 200 --- Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 --- Old_age Always - 0
9 Power_On_Hours 0x0032 084 084 --- Old_age Always - 12347
10 Spin_Retry_Count 0x0032 100 253 --- Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 --- Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 --- Old_age Always - 18
192 Power-Off_Retract_Count 0x0032 200 200 --- Old_age Always - 1
193 Load_Cycle_Count 0x0032 200 200 --- Old_age Always - 174
194 Temperature_Celsius 0x0022 106 106 --- Old_age Always - 41
196 Reallocated_Event_Count 0x0032 200 200 --- Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 --- Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 --- Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 --- Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 --- Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Completed without error 00% 12347 -
# 2 Short offline Completed without error 00% 12314 -
# 3 Short offline Completed: read failure 10% 12301 3907025624
# 4 Short offline Completed: read failure 20% 12277 3907025624
# 5 Short offline Completed: read failure 20% 12253 3907025624
# 6 Short offline Completed: read failure 60% 12229 3907025624
# 7 Short offline Completed: read failure 10% 12205 3907025624
# 8 Extended offline Completed: read failure 10% 12188 3907025624
# 9 Short offline Completed: read failure 10% 12181 3907025624
#10 Short offline Completed: read failure 10% 12157 3907025624
#11 Short offline Completed: read failure 20% 12133 3907025624
#12 Short offline Completed: read failure 40% 12109 3907025624
#13 Short offline Completed: read failure 10% 12085 3907025624
#14 Short offline Completed: read failure 60% 12061 3907025624
#15 Short offline Completed: read failure 60% 12037 3907025624
#16 Extended offline Completed: read failure 10% 12019 3907025624
#17 Short offline Completed: read failure 60% 12013 3907025624
#18 Short offline Completed: read failure 60% 11990 3907025624
#19 Short offline Completed: read failure 60% 11966 3907025624
#20 Short offline Completed: read failure 10% 11942 3907025624
#21 Short offline Completed: read failure 20% 11918 3907025624
19 of 19 failed self-tests are outdated by newer successful extended offline self-test # 1
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay.Thanks, -Bill
