r0b0ty
- Jul 5, 2018
Hi, guys.
I'm having trouble understanding why the SMART tasks I've set up don't run. I'm new to this, so it is quite probable that I misinterpreted how the FreeNAS guide described the feature.
I scheduled the tests (see image) for the first time on Monday, so I was expecting one to run on Tuesday, yesterday, and tonight. Well none have run, and I see none scheduled for ada0 and a couple of sporadic, odd ones for ada1 and ada2. I've rebooted the machine, but no change. Can you please point to what I'm doing wrong?!?
The guide suggests running the following shell commands for more information and verification. The tests below are old (part of the burn-in process I did a while back).
Output of smartctl -l selftest /dev/ada0
Output of smartctl -l selftest /dev/ada1
Output of smartd -q showtests
root@guardabarranco:~ # smartctl -l selftest /dev/ada0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
# 1 Short offline Completed without error 00% 3 -Output of smartctl -l selftest /dev/ada1
root@guardabarranco:~ # smartctl -l selftest /dev/ada1
# 1 Extended offline Completed without error 00% 81 -
# 2 Short offline Completed without error 00% 73 -
# 3 Extended offline Completed without error 00% 10 -
# 4 Short offline Completed without error 00% 3 -Output of smartd -q showtests
root@guardabarranco:~ # smartd -q showtests
smartd 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Opened configuration file /usr/local/etc/smartd.conf
Configuration file /usr/local/etc/smartd.conf parsed.
Device: /dev/ada2, opened
Device: /dev/ada2, WDC WD40EFRX-68N32N0, S/N:WD-WCC7K2XS6Y7K, WWN:5-0014ee-2650c066b, FW:82.00A82, 4.00 TB
Device: /dev/ada2, found in smartd database: Western Digital Red
Device: /dev/ada2, is SMART capable. Adding to "monitor" list.
Device: /dev/ada1, opened
Device: /dev/ada1, WDC WD40EFRX-68N32N0, S/N:WD-WCC7K2FFF87P, WWN:5-0014ee-26535b8db, FW:82.00A82, 4.00 TB
Device: /dev/ada1, found in smartd database: Western Digital Red
Device: /dev/ada1, is SMART capable. Adding to "monitor" list.
Device: /dev/ada0, opened
Device: /dev/ada0, SanDisk SDSA6GM-016G-1006, S/N:141792401188, WWN:5-001b44-c0f115324, FW:U221006, 16.0 GB
Device: /dev/ada0, not found in smartd database.
Device: /dev/ada0, can't monitor Current_Pending_Sector count - no Attribute 197
Device: /dev/ada0, is SMART capable. Adding to "monitor" list.
Monitoring 3 ATA/SATA, 0 SCSI/SAS and 0 NVMe devices
Next scheduled self tests (at most 5 of each type per device):
Device: /dev/ada1, will do test 1 of type L at Wed Aug 29 00:02:17 2018 EDT
Device: /dev/ada2, will do test 1 of type L at Thu Nov 1 00:02:17 2018 EDT
Device: /dev/ada2, will do test 2 of type L at Thu Nov 15 00:02:17 2018 EST
Totals [Thu Aug 23 16:32:17 2018 EDT - Wed Nov 21 15:32:17 2018 EST]:
Device: /dev/ada2, will do 2 tests of type L
Device: /dev/ada2, will do 0 tests of type S
Device: /dev/ada2, will do 0 tests of type C
Device: /dev/ada2, will do 0 tests of type O
Device: /dev/ada1, will do 1 test of type L
Device: /dev/ada1, will do 0 tests of type S
Device: /dev/ada1, will do 0 tests of type C
Device: /dev/ada1, will do 0 tests of type O
Device: /dev/ada0, will do 0 tests of type L
Device: /dev/ada0, will do 0 tests of type S
Device: /dev/ada0, will do 0 tests of type C
Device: /dev/ada0, will do 0 tests of type O
