SMART short tests are useful!
A few days ago, my backup server sent me an email about one of the drives (they're all late 2015 3TB WD Reds) had a pending sector. Naturally, I checked the SMART data and most of the failure indicators were low, but non-zero. Since it's a RAIDZ2 pool which is a backup of the main server, I thought I'd let it evolve and see if it degraded further. It did and, more interestingly, it failed a SMART short test:
[root@backup] ~# smartctl -x /dev/ada0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD30EFRX-68EUZN0
Serial Number:	WD-XXXXXXXXXXXX
LU WWN Device Id: 5 0014ee 261d2647b
Firmware Version: 82.00A82
User Capacity:	3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Thu Apr 13 18:39:58 2017 WEST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  ( 121) The previous self-test completed having
										the read element of the test failed.
data collection:				(39540) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 397) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x703d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAGS	VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	9
  3 Spin_Up_Time			POS--K   184   180   021	-	5758
  4 Start_Stop_Count		-O--CK   100   100   000	-	42
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	2
  7 Seek_Error_Rate		 -OSR-K   100   253   000	-	0
  9 Power_On_Hours		  -O--CK   091   091   000	-	6715
10 Spin_Retry_Count		-O--CK   100   253   000	-	0
11 Calibration_Retry_Count -O--CK   100   253   000	-	0
12 Power_Cycle_Count	   -O--CK   100   100   000	-	42
192 Power-Off_Retract_Count -O--CK   200   200   000	-	28
193 Load_Cycle_Count		-O--CK   200   200   000	-	1881
194 Temperature_Celsius	 -O---K   120   115   000	-	30
196 Reallocated_Event_Count -O--CK   198   198   000	-	2
197 Current_Pending_Sector  -O--CK   200   200   000	-	1
198 Offline_Uncorrectable   ----CK   100   253   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	1
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	6
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
							|||____ S speed/performance
							||_____ O updated online
							|______ P prefailure warning
General Purpose Log Directory Version 1
SMART		   Log Directory Version 1 [multi-sector log support]
Address	Access  R/W   Size  Description
0x00	   GPL,SL  R/O	  1  Log Directory
0x01		   SL  R/O	  1  Summary SMART error log
0x02		   SL  R/O	  5  Comprehensive SMART error log
0x03	   GPL	 R/O	  6  Ext. Comprehensive SMART error log
0x06		   SL  R/O	  1  SMART self-test log
0x07	   GPL	 R/O	  1  Extended self-test log
0x09		   SL  R/W	  1  Selective self-test log
0x10	   GPL	 R/O	  1  SATA NCQ Queued Error log
0x11	   GPL	 R/O	  1  SATA Phy Event Counters log
0x21	   GPL	 R/O	  1  Write stream error log
0x22	   GPL	 R/O	  1  Read stream error log
0x80-0x9f  GPL,SL  R/W	 16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS	  16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS	   1  Device vendor specific log
0xbd	   GPL,SL  VS	   1  Device vendor specific log
0xc0	   GPL,SL  VS	   1  Device vendor specific log
0xc1	   GPL	 VS	  93  Device vendor specific log
0xe0	   GPL,SL  R/W	  1  SCT Command/Status
0xe1	   GPL,SL  R/W	  1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 1
		CR	 = Command Register
		FEATR  = Features Register
		COUNT  = Count (was: Sector Count) Register
		LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
		LH	 = LBA High (was: Cylinder High) Register	]   LBA
		LM	 = LBA Mid (was: Cylinder Low) Register	  ] Register
		LL	 = LBA Low (was: Sector Number) Register	 ]
		DV	 = Device (was: Device/Head) Register
		DC	 = Device Control Register
		ER	 = Error register
		ST	 = Status register
Error 1 [0] occurred at disk power-on lifetime: 6649 hours (277 days + 1 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  40 -- 51 00 00 00 00 06 1a 5f c8 40 00  Error: UNC at LBA = 0x061a5fc8 = 102391752
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 01 00 00 68 00 00 06 1a 60 c0 40 08 27d+21:22:30.679  READ FPDMA QUEUED
  60 01 00 00 60 00 00 06 1a 5f c0 40 08 27d+21:22:30.678  READ FPDMA QUEUED
  60 01 00 00 58 00 00 06 1a 5e c0 40 08 27d+21:22:30.677  READ FPDMA QUEUED
  60 01 00 00 50 00 00 06 1a 5d c0 40 08 27d+21:22:30.677  READ FPDMA QUEUED
  60 00 80 00 48 00 00 06 1a 5c a8 40 08 27d+21:22:30.667  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed: read failure	   90%	  6697		 102391753
# 2  Short offline	   Completed without error	   00%	  6673		 -
# 3  Short offline	   Completed without error	   00%	  6650		 -
# 4  Short offline	   Completed without error	   00%	  6625		 -
# 5  Short offline	   Completed without error	   00%	  6601		 -
# 6  Short offline	   Completed without error	   00%	  6577		 -
# 7  Short offline	   Completed without error	   00%	  6553		 -
# 8  Short offline	   Completed without error	   00%	  6529		 -
# 9  Short offline	   Completed without error	   00%	  6505		 -
#10  Short offline	   Completed without error	   00%	  6481		 -
#11  Short offline	   Completed without error	   00%	  6457		 -
#12  Short offline	   Completed without error	   00%	  6433		 -
#13  Extended offline	Completed without error	   00%	  6417		 -
#14  Short offline	   Completed without error	   00%	  6385		 -
#15  Short offline	   Completed without error	   00%	  6361		 -
#16  Short offline	   Completed without error	   00%	  6337		 -
#17  Short offline	   Completed without error	   00%	  6318		 -
#18  Short offline	   Completed without error	   00%	  6289		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
SCT Status Version:				  3
SCT Version (vendor specific):	   258 (0x0102)
SCT Support Level:				   1
Device State:						Active (0)
Current Temperature:					30 Celsius
Power Cycle Min/Max Temperature:	 26/30 Celsius
Lifetime	Min/Max Temperature:	  2/35 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:	 2
Temperature Sampling Period:		 1 minute
Temperature Logging Interval:		1 minute
Min/Max recommended Temperature:	  0/60 Celsius
Min/Max Temperature Limit:		   -41/85 Celsius
Temperature History Size (Index):	478 (161)
Index	Estimated Time   Temperature Celsius
162	2017-04-13 10:42	30  ***********
...	..(298 skipped).	..  ***********
461	2017-04-13 15:41	30  ***********
462	2017-04-13 15:42	29  **********
...	..( 14 skipped).	..  **********
477	2017-04-13 15:57	29  **********
   0	2017-04-13 15:58	30  ***********
...	..(160 skipped).	..  ***********
161	2017-04-13 18:39	30  ***********
SCT Error Recovery Control:
		   Read:	 70 (7.0 seconds)
		  Write:	 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID	  Size	 Value  Description
0x0001  2			0  Command failed due to ICRC error
0x0002  2			0  R_ERR response for data FIS
0x0003  2			0  R_ERR response for device-to-host data FIS
0x0004  2			0  R_ERR response for host-to-device data FIS
0x0005  2			0  R_ERR response for non-data FIS
0x0006  2			0  R_ERR response for device-to-host non-data FIS
0x0007  2			0  R_ERR response for host-to-device non-data FIS
0x0008  2			0  Device-to-host non-data FIS retries
0x0009  2			5  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2			6  Device-to-host register FISes sent due to a COMRESET
0x000b  2			0  CRC errors within host-to-device FIS
0x000f  2			0  R_ERR response for host-to-device data FIS, CRC
0x0012  2			0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4	  2648897  Vendor specific
This is interesting, since it proves that SMART short tests do catch some failures on their own. In turn, that shows that it makes sense to run them daily, between long tests.
For reference, here's another drive from the server, in nominal condition:
- The following disk is nominal
[root@backup] ~# smartctl -x /dev/ada1
LU WWN Device Id: 5 0014ee 2b7287b32
Local Time is:	Thu Apr 13 18:41:40 2017 WEST
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(38580) seconds.
										command.
										power-saving mode.
recommended polling time:		( 387) minutes.
  1 Raw_Read_Error_Rate	 POSR-K   200   200   051	-	0
  3 Spin_Up_Time			POS--K   187   182   021	-	5650
  4 Start_Stop_Count		-O--CK   100   100   000	-	62
  5 Reallocated_Sector_Ct   PO--CK   200   200   140	-	0
  9 Power_On_Hours		  -O--CK   090   090   000	-	7978
12 Power_Cycle_Count	   -O--CK   100   100   000	-	62
192 Power-Off_Retract_Count -O--CK   200   200   000	-	44
193 Load_Cycle_Count		-O--CK   199   199   000	-	4253
194 Temperature_Celsius	 -O---K   119   114   000	-	31
196 Reallocated_Event_Count -O--CK   200   200   000	-	0
197 Current_Pending_Sector  -O--CK   200   200   000	-	0
199 UDMA_CRC_Error_Count	-O--CK   200   200   000	-	0
200 Multi_Zone_Error_Rate   ---R--   200   200   000	-	0
							||||||_ K auto-keep
							|||||__ C event count
							||||___ R error rate
No Errors Logged
# 1  Short offline	   Completed without error	   00%	  7959		 -
# 2  Short offline	   Completed without error	   00%	  7935		 -
# 3  Short offline	   Completed without error	   00%	  7922		 -
# 4  Short offline	   Completed without error	   00%	  7888		 -
# 5  Short offline	   Completed without error	   00%	  7864		 -
# 6  Short offline	   Completed without error	   00%	  7840		 -
# 7  Short offline	   Completed without error	   00%	  7816		 -
# 8  Short offline	   Completed without error	   00%	  7792		 -
# 9  Short offline	   Completed without error	   00%	  7768		 -
#10  Short offline	   Completed without error	   00%	  7744		 -
#11  Short offline	   Completed without error	   00%	  7720		 -
#12  Short offline	   Completed without error	   00%	  7696		 -
#13  Extended offline	Completed without error	   00%	  7680		 -
#14  Short offline	   Completed without error	   00%	  7648		 -
#15  Short offline	   Completed without error	   00%	  7624		 -
#16  Short offline	   Completed without error	   00%	  7600		 -
#17  Short offline	   Completed without error	   00%	  7576		 -
#18  Short offline	   Completed without error	   00%	  7552		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
Current Temperature:					31 Celsius
Power Cycle Min/Max Temperature:	 27/31 Celsius
Lifetime	Min/Max Temperature:	  2/36 Celsius
Vendor specific:
Temperature History Size (Index):	478 (197)
198	2017-04-13 10:44	31  ************
...	..(476 skipped).	..  ************
197	2017-04-13 18:41	31  ************
0x8000  4	  2649015  Vendor specific
Fun fact: This pool had been needing 24 hours for a scrub, which really isn't warranted given that it's low-use and far from full. With the new drive resilvering, it's looking like ~3 hours for a resilver.
joeschmuck
Old Man
This is interesting for your failed drive. I would have expected the overall summary to have been updated to FAILED. Do you know why this is?
I don't even look at that field anymore, I've seen that happen very often.
