Self-Test Log error count increased (SMART result)
Hi
I have two FreeNAS servers running both with 4 * 2TB WD Red.
These or running on HP Microservers for home use.
Both the disks are out of the three-year warranty 1 by 6 months and the other by 9 months
Both have reported:
/dev/ada2 on one setup
/dev/ada3 on the other setup
Below are the outputs on both the drives
smartctl -x /dev/ada3
smartctl -x /dev/ada2
from reading the forum this could indicate a disk failing or just potentially a fault reading a sector which could be fixed by a resilver
Can anyone offer a more knowledgable assessment, I have done a resilver before by replacing a failed disk but how would I start a resilver without replacing the disk?
Results From smartctl -x /dev/ada3
root@GPSan1:~ # smartctl -x /dev/ada3
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red
Device Model:     WDC WD20EFRX-68EUZN0
Serial Number:    WD-WCC4M2ZPD4SD
LU WWN Device Id: 5 0014ee 2627fa847
Firmware Version: 82.00A82
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Rotation Rate:    5400 rpm
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Tue Sep  1 14:39:14 2020 BST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 118) The previous self-test completed having
                                        the read element of the test failed.
data collection:                (26580) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 268) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x703d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR-K   200   200   051    -    0
  3 Spin_Up_Time            POS--K   168   164   021    -    4583
  4 Start_Stop_Count        -O--CK   100   100   000    -    30
  5 Reallocated_Sector_Ct   PO--CK   200   200   140    -    0
  7 Seek_Error_Rate         -OSR-K   200   200   000    -    0
  9 Power_On_Hours          -O--CK   065   065   000    -    25789
 10 Spin_Retry_Count        -O--CK   100   253   000    -    0
 11 Calibration_Retry_Count -O--CK   100   253   000    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    30
192 Power-Off_Retract_Count -O--CK   200   200   000    -    12
193 Load_Cycle_Count        -O--CK   200   200   000    -    462
194 Temperature_Celsius     -O---K   112   108   000    -    35
196 Reallocated_Event_Count -O--CK   200   200   000    -    0
197 Current_Pending_Sector  -O--CK   200   200   000    -    0
198 Offline_Uncorrectable   ----CK   100   253   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
200 Multi_Zone_Error_Rate   ---R--   100   253   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      6  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa0-0xa7  GPL,SL  VS      16  Device vendor specific log
0xa8-0xb7  GPL,SL  VS       1  Device vendor specific log
0xbd       GPL,SL  VS       1  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL     VS      93  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed: read failure       60%     25777         3907027024
SCT Status Version:                  3
SCT Version (vendor specific):       258 (0x0102)
Device State:                        Active (0)
Current Temperature:                    35 Celsius
Power Cycle Min/Max Temperature:     22/40 Celsius
Lifetime    Min/Max Temperature:     15/40 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/60 Celsius
Min/Max Temperature Limit:           -41/85 Celsius
Temperature History Size (Index):    478 (373)
                                        was never started.
                                        command.
                                        power-saving mode.
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Vendor specific:
Index    Estimated Time   Temperature Celsius
 374    2020-09-01 06:42    35  ****************
 ...    ..(192 skipped).    ..  ****************
  89    2020-09-01 09:55    35  ****************
  90    2020-09-01 09:56    34  ***************
 ...    ..(177 skipped).    ..  ***************
 268    2020-09-01 12:54    34  ***************
 269    2020-09-01 12:55    35  ****************
 ...    ..( 30 skipped).    ..  ****************
 300    2020-09-01 13:26    35  ****************
 301    2020-09-01 13:27    34  ***************
 ...    ..(  2 skipped).    ..  ***************
 304    2020-09-01 13:30    34  ***************
 305    2020-09-01 13:31    35  ****************
 ...    ..( 67 skipped).    ..  ****************
 373    2020-09-01 14:39    35  ****************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2           17  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           15  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000f  2            0  R_ERR response for host-to-device data FIS, CRC
0x0012  2            0  R_ERR response for host-to-device non-data FIS, CRC
0x8000  4      9499496  Vendor specific
Results From smartctl -x /dev/ada2
root@HomeShare:~ # smartctl -x /dev/ada2
Serial Number:    WD-WCC4M3VDF48V
LU WWN Device Id: 5 0014ee 2b6782dbf
Local Time is:    Tue Sep  1 14:49:07 2020 BST
                                        was never started.
Self-test execution status:      ( 114) The previous self-test completed having
data collection:                (27540) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 278) minutes.
  3 Spin_Up_Time            POS--K   172   169   021    -    4383
  4 Start_Stop_Count        -O--CK   100   100   000    -    38
  9 Power_On_Hours          -O--CK   047   047   000    -    38913
 12 Power_Cycle_Count       -O--CK   100   100   000    -    37
192 Power-Off_Retract_Count -O--CK   200   200   000    -    4
193 Load_Cycle_Count        -O--CK   200   200   000    -    424
194 Temperature_Celsius     -O---K   118   105   000    -    29
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
# 1  Short offline       Completed: read failure       20%     38899         11490368
# 2  Short offline       Completed: read failure       20%     38184         11490368
# 3  Short offline       Completed without error       00%     38016         -
# 4  Short offline       Completed without error       00%     37848         -
# 5  Short offline       Completed without error       00%     37680         -
# 6  Short offline       Completed without error       00%     37513         -
# 7  Short offline       Completed without error       00%     37345         -
# 8  Short offline       Completed without error       00%     37177         -
# 9  Short offline       Completed without error       00%     37009         -
#10  Short offline       Completed without error       00%     36841         -
#11  Short offline       Completed without error       00%     36673         -
#12  Short offline       Completed without error       00%     36506         -
#13  Short offline       Completed without error       00%     36338         -
#14  Short offline       Completed without error       00%     36170         -
#15  Short offline       Completed without error       00%     36002         -
#16  Short offline       Completed without error       00%     35834         -
#17  Short offline       Completed without error       00%     35666         -
#18  Short offline       Completed without error       00%     35498         -
Current Temperature:                    29 Celsius
Power Cycle Min/Max Temperature:     23/32 Celsius
Lifetime    Min/Max Temperature:     14/43 Celsius
Vendor specific:
Temperature History Size (Index):    478 (122)
 123    2020-09-01 06:52    29  **********
 ...    ..(476 skipped).    ..  **********
 122    2020-09-01 14:49    29  **********
0x0009  2           77  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2           77  Device-to-host register FISes sent due to a COMRESET
Pitfrr
First could please edit your message and put the SMART result in the code tags, that would improve readability... thanks.
Besides of the short test issue, the SMART data looks good.
But smething got my attention: those drives never performed long tests (and ada3 a short test only once!).
So you should perform long tests on these drives (and also make sure the long tests are planned in for the other drives).
I'd say, perform the long test and see what comes out...
Depending on the result, I would:
- rerun the short tests if the long tests are ok
- closely monitor the disks to see if it degrades in time or not (that is also depending on the data stored on the volume, its criticality, if backups are available, the RAIDz used, ...)
- run several passes of badblocks on those disks and watch the outcome
- eventually change the drives if too many errors occur
- if one is your backup server and the other the main server, I'd swap some drives so that on the main server all drives are healthy, so no stress on the data and then work on the backup server
Thanks for your reply
Changed to make it slightly more readable
I have scheduled in a LONG test for all drives on both servers tonight and will check the results
I will complete a Badblocks check also
Pitfrr
By the way, to do a resilver without changing a disk, just do a scrub.
(and they should be planned regularly also)
You could run one and check that there are no checksum errors, just to be sure...
