Device: /dev/ada2, 1 Offline uncorrectable sectors
architect
Hi all,
I am an amateur user and running TrueNAS off an old PC. Recently I have received two of these errors on different drives:
CRITICAL Device: /dev/ada2, 1 Offline uncorrectable sectors. 2022-11-25 02:06:32 (America/New_York)
CRITICAL Device: /dev/ada1, 2 Currently unreadable (pending) sectors. 2022-11-25 03:36:31 (America/New_York)
CRITICAL Device: /dev/ada1, 2 Offline uncorrectable sectors. 2022-11-25 03:36:31 (America/New_York)
    Device Model:     WDC WD80EFBX-68AZZN0
    Serial Number:    VRKRTTSK
    LU WWN Device Id: 5 000cca 0c2f4a3c4
    Firmware Version: 85.00A85
    User Capacity:    8,001,563,222,016 bytes [8.00 TB]
    Rotation Rate:    7200 rpm
    Form Factor:      3.5 inches
    Device is:        Not in smartctl database [for details use: -P showall]
    ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
    SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 3.0 Gb/s)
    Local Time is:    Fri Nov 25 09:56:24 2022 EST
    SMART support is: Enabled
    AAM feature is:   Unavailable
    APM feature is:   Disabled
    Rd look-ahead is: Enabled
    Write cache is:   Enabled
    DSN feature is:   Unavailable
    ATA Security is:  Disabled, frozen [SEC2]
    Wt Cache Reorder: Enabled
    General SMART Values:
    Offline data collection status:  (0x82) Offline data collection activity
                                            was completed without error.
    Self-test execution status:      ( 121) The previous self-test completed having
                                            the read element of the test failed.
    data collection:                (   87) seconds.
    capabilities:                    (0x5b) SMART execute Offline immediate.
                                            command.
                                            Self-test supported.
                                            power-saving mode.
    Short self-test routine
    Extended self-test routine
    recommended polling time:        ( 919) minutes.
    SCT capabilities:              (0x003d) SCT Status supported.
                                            SCT Data Table supported.
    ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
      1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
      2 Throughput_Performance  --S---   127   127   054    -    112
      3 Spin_Up_Time            POS---   194   194   024    -    352 (Average 488)
      4 Start_Stop_Count        -O--C-   100   100   000    -    93
      5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
      7 Seek_Error_Rate         -O-R--   100   100   067    -    0
      8 Seek_Time_Performance   --S---   128   128   020    -    18
      9 Power_On_Hours          -O--C-   100   100   000    -    5140
     10 Spin_Retry_Count        -O--C-   100   100   060    -    0
     12 Power_Cycle_Count       -O--CK   100   100   000    -    22
    192 Power-Off_Retract_Count -O--CK   100   100   000    -    304
    193 Load_Cycle_Count        -O--C-   100   100   000    -    304
    194 Temperature_Celsius     -O----   130   130   000    -    50 (Min/Max 22/61)
    196 Reallocated_Event_Count -O--CK   100   100   000    -    0
    197 Current_Pending_Sector  -O---K   100   100   000    -    0
    198 Offline_Uncorrectable   ---R--   100   100   000    -    1
    199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                                ||||||_ K auto-keep
                                |||||__ C event count
                                ||||___ R error rate
                                |||____ S speed/performance
                                ||_____ O updated online
                                |______ P prefailure warning
    General Purpose Log Directory Version 1
    SMART           Log Directory Version 1 [multi-sector log support]
    Address    Access  R/W   Size  Description
    0x00       GPL,SL  R/O      1  Log Directory
    0x01           SL  R/O      1  Summary SMART error log
    0x02           SL  R/O      1  Comprehensive SMART error log
    0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
    0x04       GPL     R/O    256  Device Statistics log
    0x04       SL      R/O    255  Device Statistics log
    0x06           SL  R/O      1  SMART self-test log
    0x07       GPL     R/O      1  Extended self-test log
    0x08       GPL     R/O      2  Power Conditions log
    0x09           SL  R/W      1  Selective self-test log
    0x0c       GPL     R/O   5501  Pending Defects log
    0x10       GPL     R/O      1  NCQ Command Error log
    0x11       GPL     R/O      1  SATA Phy Event Counters log
    0x12       GPL     R/O      1  SATA NCQ Non-Data log
    0x13       GPL     R/O      1  SATA NCQ Send and Receive log
    0x15       GPL     R/W      1  Rebuild Assist log
    0x21       GPL     R/O      1  Write stream error log
    0x22       GPL     R/O      1  Read stream error log
    0x24       GPL     R/O    256  Current Device Internal Status Data log
    0x25       GPL     R/O    256  Saved Device Internal Status Data log
    0x2f       GPL     -        1  Set Sector Configuration
    0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
    0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
    0xe0       GPL,SL  R/W      1  SCT Command/Status
    0xe1       GPL,SL  R/W      1  SCT Data Transfer
    SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
    Device Error Count: 4
            CR     = Command Register
            FEATR  = Features Register
            COUNT  = Count (was: Sector Count) Register
            LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
            LH     = LBA High (was: Cylinder High) Register    ]   LBA
            LM     = LBA Mid (was: Cylinder Low) Register      ] Register
            LL     = LBA Low (was: Sector Number) Register     ]
            DV     = Device (was: Device/Head) Register
            DC     = Device Control Register
            ER     = Error register
            ST     = Status register
    Error 4 [3] occurred at disk power-on lifetime: 5062 hours (210 days + 22 hours)
      ER -- ST COUNT  LBA_48  LH LM LL DV DC
      40 -- 51 07 50 00 00 67 12 32 70 40 00  Error: UNC 1872 sectors at LBA = 0x67123270 = 1729245808
      CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
      25 00 00 07 60 00 00 67 12 32 60 40 00 19d+13:03:42.080  READ DMA EXT
      25 00 00 07 60 00 00 67 12 32 60 40 00 19d+13:03:36.938  READ DMA EXT
      25 00 00 07 60 00 00 67 12 32 60 40 00 19d+13:03:34.363  READ DMA EXT
      25 00 00 07 60 00 00 67 12 32 60 40 00 19d+13:03:31.788  READ DMA EXT
      25 00 00 06 f0 00 00 67 12 2a 88 40 00 19d+13:03:31.776  READ DMA EXT
    Error 3 [2] occurred at disk power-on lifetime: 5062 hours (210 days + 22 hours)
      25 00 00 07 60 00 00 67 12 32 60 40 00 19d+13:03:39.513  READ DMA EXT
      25 00 00 07 88 00 00 67 12 23 00 40 00 19d+13:03:31.772  READ DMA EXT
    Error 2 [1] occurred at disk power-on lifetime: 5062 hours (210 days + 22 hours)
      25 00 00 07 60 00 00 67 12 1b a0 40 00 19d+13:03:31.768  READ DMA EXT
    Error 1 [0] occurred at disk power-on lifetime: 5062 hours (210 days + 22 hours)
      25 00 00 00 08 00 00 67 12 1b 98 40 00 19d+13:03:31.768  READ DMA EXT
    SMART Extended Self-test Log Version: 1 (1 sectors)
    # 1  Short offline       Completed: read failure       90%      5012         1729245808
    # 2  Extended offline    Completed: read failure       80%      4989         1729245808
    # 3  Short offline       Completed without error       00%      4844         -
    # 4  Short offline       Completed without error       00%      4676         -
    # 5  Extended offline    Completed without error       00%      4666         -
    # 6  Short offline       Completed without error       00%      4507         -
    # 7  Short offline       Completed without error       00%      4339         -
    # 8  Extended offline    Completed without error       00%      4258         -
    # 9  Short offline       Completed without error       00%      4171         -
    #10  Short offline       Completed without error       00%      4003         -
    #11  Extended offline    Completed without error       00%      3922         -
    #12  Short offline       Completed without error       00%      3835         -
    #13  Short offline       Completed without error       00%      3667         -
    #14  Extended offline    Completed without error       00%      3538         -
    #15  Short offline       Completed without error       00%      3499         -
    #16  Short offline       Completed without error       00%      3331         -
    #17  Extended offline    Completed without error       00%      3202         -
    #18  Short offline       Completed without error       00%      3163         -
    #19  Short offline       Completed without error       00%      2995         -
    SCT Status Version:                  3
    SCT Version (vendor specific):       256 (0x0100)
    Device State:                        Active (0)
    Current Temperature:                    50 Celsius
    Power Cycle Min/Max Temperature:     45/53 Celsius
    Lifetime    Min/Max Temperature:     22/61 Celsius
    Under/Over Temperature Limit Count:   0/0
    SCT Temperature History Version:     2
    Temperature Sampling Period:         1 minute
    Temperature Logging Interval:        1 minute
    Min/Max recommended Temperature:      0/65 Celsius
    Min/Max Temperature Limit:           -40/70 Celsius
    Temperature History Size (Index):    128 (117)
    Index    Estimated Time   Temperature Celsius
     118    2022-11-25 07:49    49  ******************************
     ...    ..(  9 skipped).    ..  ******************************
       0    2022-11-25 07:59    49  ******************************
       1    2022-11-25 08:00    50  *******************************
       2    2022-11-25 08:01    49  ******************************
     ...    ..(  5 skipped).    ..  ******************************
       8    2022-11-25 08:07    49  ******************************
       9    2022-11-25 08:08    50  *******************************
     ...    ..(  4 skipped).    ..  *******************************
      14    2022-11-25 08:13    50  *******************************
      15    2022-11-25 08:14    49  ******************************
      16    2022-11-25 08:15    50  *******************************
      17    2022-11-25 08:16    49  ******************************
      18    2022-11-25 08:17    50  *******************************
      19    2022-11-25 08:18    50  *******************************
      20    2022-11-25 08:19    49  ******************************
      21    2022-11-25 08:20    50  *******************************
      22    2022-11-25 08:21    50  *******************************
      23    2022-11-25 08:22    50  *******************************
      24    2022-11-25 08:23    49  ******************************
      25    2022-11-25 08:24    49  ******************************
      26    2022-11-25 08:25    50  *******************************
     ...    ..(  8 skipped).    ..  *******************************
      35    2022-11-25 08:34    50  *******************************
      36    2022-11-25 08:35    49  ******************************
      37    2022-11-25 08:36    50  *******************************
      38    2022-11-25 08:37    50  *******************************
      39    2022-11-25 08:38    49  ******************************
     ...    ..(  2 skipped).    ..  ******************************
      42    2022-11-25 08:41    49  ******************************
      43    2022-11-25 08:42    50  *******************************
      44    2022-11-25 08:43    49  ******************************
      50    2022-11-25 08:49    49  ******************************
      51    2022-11-25 08:50    50  *******************************
      52    2022-11-25 08:51    50  *******************************
      53    2022-11-25 08:52    50  *******************************
      54    2022-11-25 08:53    49  ******************************
      55    2022-11-25 08:54    50  *******************************
      56    2022-11-25 08:55    50  *******************************
      57    2022-11-25 08:56    50  *******************************
      58    2022-11-25 08:57    49  ******************************
      59    2022-11-25 08:58    50  *******************************
      60    2022-11-25 08:59    49  ******************************
      61    2022-11-25 09:00    49  ******************************
      62    2022-11-25 09:01    50  *******************************
      63    2022-11-25 09:02    50  *******************************
      64    2022-11-25 09:03    49  ******************************
     ...    ..( 16 skipped).    ..  ******************************
      81    2022-11-25 09:20    49  ******************************
      82    2022-11-25 09:21    50  *******************************
     ...    ..( 33 skipped).    ..  *******************************
     116    2022-11-25 09:55    50  *******************************
     117    2022-11-25 09:56    49  ******************************
    SCT Error Recovery Control:
               Read:     70 (7.0 seconds)
              Write:     70 (7.0 seconds)
    Device Statistics (GP Log 0x04)
    Page  Offset Size        Value Flags Description
    0x01  =====  =               =  ===  == General Statistics (rev 1) ==
    0x01  0x008  4              22  ---  Lifetime Power-On Resets
    0x01  0x010  4            5140  ---  Power-on Hours
    0x01  0x018  6     16453275059  ---  Logical Sectors Written
    0x01  0x020  6       322238047  ---  Number of Write Commands
    0x01  0x028  6     35493305546  ---  Logical Sectors Read
    0x01  0x030  6        62300215  ---  Number of Read Commands
    0x01  0x038  6     18504613800  ---  Date and Time TimeStamp
    0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
    0x03  0x008  4            5075  ---  Spindle Motor Power-on Hours
    0x03  0x010  4            5075  ---  Head Flying Hours
    0x03  0x018  4             304  ---  Head Load Events
    0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
    0x03  0x028  4               5  ---  Read Recovery Attempts
    0x03  0x030  4               0  ---  Number of Mechanical Start Failures
    0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
    0x04  0x008  4               4  ---  Number of Reported Uncorrectable Errors
    0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
    0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
    0x05  0x008  1              50  ---  Current Temperature
    0x05  0x010  1              49  N--  Average Short Term Temperature
    0x05  0x018  1              49  N--  Average Long Term Temperature
    0x05  0x020  1              61  ---  Highest Temperature
    0x05  0x028  1              22  ---  Lowest Temperature
    0x05  0x030  1              54  N--  Highest Average Short Term Temperature
    0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
    0x05  0x040  1              49  N--  Highest Average Long Term Temperature
    0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
    0x05  0x050  4               0  ---  Time in Over-Temperature
    0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
    0x05  0x060  4               0  ---  Time in Under-Temperature
    0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
    0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
    0x06  0x008  4              59  ---  Number of Hardware Resets
    0x06  0x010  4              15  ---  Number of ASR Events
    0x06  0x018  4               0  ---  Number of Interface CRC Errors
    0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
    0xff  0x040  7               6  ---  Vendor Specific
    0xff  0x048  7              96  ---  Vendor Specific
    0xff  0x050  7               0  ---  Vendor Specific
    0xff  0x058  7               0  ---  Vendor Specific
    0xff  0x060  7               0  ---  Vendor Specific
    0xff  0x068  7             271  ---  Vendor Specific
    0xff  0x070  7               0  ---  Vendor Specific
    0xff  0x078  7               0  ---  Vendor Specific
    0xff  0x080  7             148  ---  Vendor Specific
                                    |||_ C monitored condition met
                                    ||__ D supports DSN
                                    |___ N normalized value
    Pending Defects log (GP Log 0x0c)
    No Defects Logged
    SATA Phy Event Counters (GP Log 0x11)
    ID      Size     Value  Description
    0x0001  2            0  Command failed due to ICRC error
    0x0002  2            0  R_ERR response for data FIS
    0x0003  2            0  R_ERR response for device-to-host data FIS
    0x0004  2            0  R_ERR response for host-to-device data FIS
    0x0005  2            0  R_ERR response for non-data FIS
    0x0008  2            0  Device-to-host non-data FIS retries
    0x0009  2            9  Transition from drive PhyRdy to drive PhyNRdy
    0x000a  2            8  Device-to-host register FISes sent due to a COMRESET
    0x000b  2            0  CRC errors within host-to-device FIS
    0x000d  2            0  Non-CRC errors within host-to-device FIS
Here is the log for data2 drive. Does anyone know why this would happen at the same time for both drive? Do both drives need to be swapped now?
Thank you.
Temperature is a likely candidate; the disk you showed the SMART output for is currently at 50°C and has seen 61°C this power cycle, which is way too hot.
There are a lot of threads here on "offline uncorrectable sectors", and I'd suggest reading some of them for a much better answer. But with that said, the disk you posted the data for has failed its last two SMART self-tests--that says it needs to be replaced.
architect
Thanks for the response. My drive is still under warranty. Do you think WD would be able to see and reject based on the temp readings?
Redcoat
Yes, they'll be able to see it if they check. But, since their spec says operating range is 0-65C, seems it would be difficult for them to reject a claim on that basis alone.
Etorix
@architect The RMA process basically begins with you sending the SMART report to WD as basis for your claim, so WD should know from the start.
But do something about cooling. The case and/or fans are not adequate.
architect
Thanks for the help, folks. I'm gonna bring it back to the store since it's under one year and they can process the RMA for me. Knowing that I should replace the drive and finding the plausible cause is good enough for me. I'm not smart enough to understand all the technical details from all threads on uncorrectable sectors!
NugentS
Just do something about the temps
