Barrington Woodhams
- Mar 9, 2015
Hi
I have two FreeNAS servers running both with 4 * 2TB WD Red.
These or running on HP Microservers for home use.
Both the disks are out of the three-year warranty 1 by 6 months and the other by 9 months
Both have reported:
Self-Test Log error count increased
/dev/ada2 on one setup
/dev/ada3 on the other setup
Below are the outputs on both the drives
smartctl -x /dev/ada3
smartctl -x /dev/ada2
from reading the forum this could indicate a disk failing or just potentially a fault reading a sector which could be fixed by a resilver
Can anyone offer a more knowledgable assessment, I have done a resilver before by replacing a failed disk but how would I start a resilver without replacing the disk?
Results From smartctl -x /dev/ada3
Results From smartctl -x /dev/ada2
Both have reported:
root@GPSan1:~ # smartctl -x /dev/ada3
smartctl 7.0 2018-12-30 r4883 [FreeBSD 11.3-RELEASE-p11 amd64] (local build)
Copyright (C) 2002-18, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD20EFRX-68EUZN0
Serial Number: WD-WCC4M2ZPD4SD
LU WWN Device Id: 5 0014ee 2627fa847
Firmware Version: 82.00A82
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is: Tue Sep 1 14:39:14 2020 BST
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
Self-test execution status: ( 118) The previous self-test completed having
the read element of the test failed.
data collection: (26580) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 268) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 200 200 051 - 0
3 Spin_Up_Time POS--K 168 164 021 - 4583
4 Start_Stop_Count -O--CK 100 100 000 - 30
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 200 200 000 - 0
9 Power_On_Hours -O--CK 065 065 000 - 25789
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 30
192 Power-Off_Retract_Count -O--CK 200 200 000 - 12
193 Load_Cycle_Count -O--CK 200 200 000 - 462
194 Temperature_Celsius -O---K 112 108 000 - 35
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 0
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 100 253 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Short offline Completed: read failure 60% 25777 3907027024
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
Device State: Active (0)
Current Temperature: 35 Celsius
Power Cycle Min/Max Temperature: 22/40 Celsius
Lifetime Min/Max Temperature: 15/40 Celsius
Under/Over Temperature Limit Count: 0/0
Vendor specific:
01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (373)
was never started.
command.
power-saving mode.
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Vendor specific:
Index Estimated Time Temperature Celsius
374 2020-09-01 06:42 35 ****************
... ..(192 skipped). .. ****************
89 2020-09-01 09:55 35 ****************
90 2020-09-01 09:56 34 ***************
... ..(177 skipped). .. ***************
268 2020-09-01 12:54 34 ***************
269 2020-09-01 12:55 35 ****************
... ..( 30 skipped). .. ****************
300 2020-09-01 13:26 35 ****************
301 2020-09-01 13:27 34 ***************
... ..( 2 skipped). .. ***************
304 2020-09-01 13:30 34 ***************
305 2020-09-01 13:31 35 ****************
... ..( 67 skipped). .. ****************
373 2020-09-01 14:39 35 ****************
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 17 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 15 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 9499496 Vendor specific Results From smartctl -x /dev/ada2
root@HomeShare:~ # smartctl -x /dev/ada2
Serial Number: WD-WCC4M3VDF48V
LU WWN Device Id: 5 0014ee 2b6782dbf
Local Time is: Tue Sep 1 14:49:07 2020 BST
was never started.
Self-test execution status: ( 114) The previous self-test completed having
data collection: (27540) seconds.
command.
power-saving mode.
recommended polling time: ( 278) minutes.
3 Spin_Up_Time POS--K 172 169 021 - 4383
4 Start_Stop_Count -O--CK 100 100 000 - 38
9 Power_On_Hours -O--CK 047 047 000 - 38913
12 Power_Cycle_Count -O--CK 100 100 000 - 37
192 Power-Off_Retract_Count -O--CK 200 200 000 - 4
193 Load_Cycle_Count -O--CK 200 200 000 - 424
194 Temperature_Celsius -O---K 118 105 000 - 29
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
No Errors Logged
# 1 Short offline Completed: read failure 20% 38899 11490368
# 2 Short offline Completed: read failure 20% 38184 11490368
# 3 Short offline Completed without error 00% 38016 -
# 4 Short offline Completed without error 00% 37848 -
# 5 Short offline Completed without error 00% 37680 -
# 6 Short offline Completed without error 00% 37513 -
# 7 Short offline Completed without error 00% 37345 -
# 8 Short offline Completed without error 00% 37177 -
# 9 Short offline Completed without error 00% 37009 -
#10 Short offline Completed without error 00% 36841 -
#11 Short offline Completed without error 00% 36673 -
#12 Short offline Completed without error 00% 36506 -
#13 Short offline Completed without error 00% 36338 -
#14 Short offline Completed without error 00% 36170 -
#15 Short offline Completed without error 00% 36002 -
#16 Short offline Completed without error 00% 35834 -
#17 Short offline Completed without error 00% 35666 -
#18 Short offline Completed without error 00% 35498 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Current Temperature: 29 Celsius
Power Cycle Min/Max Temperature: 23/32 Celsius
Lifetime Min/Max Temperature: 14/43 Celsius
Vendor specific:
Temperature History Size (Index): 478 (122)
123 2020-09-01 06:52 29 **********
... ..(476 skipped). .. **********
122 2020-09-01 14:49 29 **********
0x0009 2 77 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 77 Device-to-host register FISes sent due to a COMRESET
