SMART: "No self-tests have been logged"
JoeB
In the services, i have SMART turned on with all the default settings: 30 mins, never, 0, 0, 0
The server has been running for months now, but when I read the results, I get no results?
# smartctl -l selftest /dev/ada0
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
The box is ticking like this:
tick... delay 1 sec.... tick-tick... delay 1 sec <repeat forever>
So wanted to know if its a disc about to fail or if its supposed to do that?
It only seems to tick when its not been doing anything for a while, e.g. not streaming plex or whatever.
gpsguy
Active Member
It looks like you're not running smart tests.
For a short test (a couple of minutes), use: smartctl -t short /dev/ada0
For a long test use: smartctl -t long /dev/ada0
To look at the results, use: smartctl -a /dev/ada0
If you'd like us to look at the results from the last command, post the output here and use the code tags. It will preserve the formatting, which is necessary to read the information.
Robert Trevellyan
Pony Wrangler
The SMART entry in Services sets up monitoring of the SMART status, but it doesn't run any SMART tests. For that, go to the SMART Tests section of the Tasks tab.
JoeB
ADA0:
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   177   176   021    Pre-fail  Always       -       6150
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       27
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3769
10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       26
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       7
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       59
194 Temperature_Celsius     0x0022   122   114   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   100   253   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      3769         -
ADA1:
  3 Spin_Up_Time            0x0027   176   176   021    Pre-fail  Always       -       6175
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       14
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3744
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       14
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       4
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       37
194 Temperature_Celsius     0x0022   121   112   000    Old_age   Always       -       29
No Errors Logged
# 1  Short offline       Completed without error       00%      3744         -
ADA2:
  3 Spin_Up_Time            0x0027   175   173   021    Pre-fail  Always       -       6233
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       26
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       3768
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       55
194 Temperature_Celsius     0x0022   122   113   000    Old_age   Always       -       28
No Errors Logged
# 1  Short offline       Completed without error       00%      3768         -
ADA3:
  3 Spin_Up_Time            0x0027   166   165   021    Pre-fail  Always       -       6700
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       57
No Errors Logged
JoeB
Duplicate - sorry
EDIT: As i have a post i cant delete, i may as well use it :p
The freenas is set up as 4x 3T Discs, in some configuration that gives me 5.5G usable disc space, i cant see how you can see what the raid method is and i cant remember what i set.
The discs are half full now (used 2.6T)
They are WD Red drives, 7 months old.
http://www.amazon.co.uk/gp/product/B008JJLW4M
gpsguy
Active Member
The easiest way to see how the disks are configured is to do it from the command line: zpool status
If you want us to intrepret it for you, please use the code tags. Thank you for doing it on the smartctl output.
gpsguy
Active Member
Your SMART test results look fine.
Since you hadn't run any tests and just did the short test, I'd run a long test on all of them. The long tests will take a couple of hours to run.
Do you run scrubs? If you don't know, we'll be able to see the last time one was run, if you post the output from zpool status.
JoeB
I don't run scrubs, i didn't know what they were until my USB boot stick had an issue (separate thread). I did click the scrub button a few times in the past but couldn't work out what it was doing- looked to do nothing.
I've requested a full smart scan, and it said come back in 401 minutes so I'll post the full scan results tomorrow.
Here is the zpool status result:
# zpool status
  pool: freenas-boot
state: ONLINE
        corruption.  Applications may be affected.
action: Restore the file in question if possible.  Otherwise restore the
        entire pool from backup.
   see: http://illumos.org/msg/ZFS-8000-8A
  scan: scrub repaired 0 in 0h9m with 2 errors on Mon Apr 27 01:50:20 2015
        freenas-boot  ONLINE       0     0     0
          da0p2     ONLINE       0     0     0
errors: 2 data errors, use '-v' for a list
  pool: vol1
state: ONLINE
  scan: scrub repaired 0 in 2h14m with 0 errors on Sun Mar 29 03:14:42 2015
        vol1                                            ONLINE       0     0     0
          mirror-0                                      ONLINE       0     0     0
            gptid/308e4a9f-588e-11e4-ae53-9cb6540ca823  ONLINE       0     0     0
            gptid/3166d467-588e-11e4-ae53-9cb6540ca823  ONLINE       0     0     0
          mirror-1                                      ONLINE       0     0     0
            gptid/31d88ec5-588e-11e4-ae53-9cb6540ca823  ONLINE       0     0     0
            gptid/323e2e0a-588e-11e4-ae53-9cb6540ca823  ONLINE       0     0     0
errors: No known data errors
gpsguy
Active Member
To answer your earlier question, you have 2 sets of mirrors that have been striped together to form a volume (vol1).
For many use cases, it's recommended. And, you have the ability to grow your volume easily, by adding additional sets of mirrors. You pay a lot for overhead, since you lose one drive per vdev. And, if both drives in a mirror were to fail, you'd lose your entire pool.
Many users use RAIDz2, which with 4 drives, which would offer the same amount of storage that you currently have. But, with RAIDz2, you could lose any 2 drives, without data loss. Since you're giving up the equivalent of 2 drives for parity, the sweet spot for RAIDz2 is 6 drives. Unfortunately, you can't switch from what you have to RAIDz2 without backing up your data, rebuilding your pool and restoring the data.
gpsguy
Active Member
See section 8.4 of the documentation (http://doc.freenas.org/9.3/freenas_storage.html#scrubs) to read up on scrubs. In addition to running SMART tests on a regular basis, you should also schedule scrubs to run.
Looking at the output of zpool status, we can see that there are some problems with your boot media. zpool status -v would display the files that have data errors.
I recommend that you reinstall FreeNAS on a new flash drive and restore your configuration to it. If you don't have a backup of the latter, create a backup now. You can do it via the GUI - System→General →Save Config. You'll be able to restore the settings using the GUI too.
If you are using encryption, you'll need additional information.
JoeB
Darn, i thought i'd selected Raid-z2. I'll need to borrow a 3T drive from somewhere now to convert it :(
JoeB
OK, so this issue didn't go away, i just forgot about it! I checked freeNAS yesterday and i had an alert that said "Device: /dev/ada0, 1 Currently unreadable (pending) sector", so I ran long smart tests on all drives overnight.
Here is the output of -a /dev/ada0 for all drives:
ADA0
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       39
  3 Spin_Up_Time            0x0027   179   176   021    Pre-fail  Always       -       6033
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       35
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       10493
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       34
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       10
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       145
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       1
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       4
No Errors Logged
# 1  Extended offline    Completed without error       00%     10491         -
# 2  Extended offline    Completed without error       00%      3800         -
# 3  Short offline       Completed without error       00%      3769         -
ADA1
  3 Spin_Up_Time            0x0027   179   176   021    Pre-fail  Always       -       6050
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       22
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       10468
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       22
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       111
194 Temperature_Celsius     0x0022   121   111   000    Old_age   Always       -       29
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
No Errors Logged
# 1  Extended offline    Completed without error       00%     10466         -
# 2  Extended offline    Completed without error       00%      3775         -
# 3  Short offline       Completed without error       00%      3744         -
ADA2
  3 Spin_Up_Time            0x0027   177   173   021    Pre-fail  Always       -       6116
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       34
  9 Power_On_Hours          0x0032   086   086   000    Old_age   Always       -       10492
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       133
No Errors Logged
# 1  Extended offline    Completed without error       00%     10490         -
# 2  Extended offline    Completed without error       00%      3799         -
# 3  Short offline       Completed without error       00%      3768         -
ADA3
  3 Spin_Up_Time            0x0027   170   165   021    Pre-fail  Always       -       6466
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       137
No Errors Logged
Any ideas? I don't know what these figures are trying to tell me?
gpsguy
Active Member
JoeB
I see, this is an error. Is this a serious error? e.g. will i need to RMA the drive? It is a WD red and has a 5 yr warranty.
Raw_Read_Error_Rate is not zero like the other 3 drives too, is that a drive failure?
SweetAndLow
Sweet'NASty
I world try to replace it, especially if it was under warranty.
JoeB
Ok thanks. Will the NAS still work while the drive is out or should i shut it down until i get the new drive?
SweetAndLow
Sweet'NASty
If WD warranties it just have them send you a new drive and keep using the nas. Just keep an eye on it.
Robert Trevellyan
Pony Wrangler
If you can't get a warranty replacement for a single pending sector, consider purchasing a spare. Burn it in, then keep it on the shelf.
A single pending sector is no big deal, but if the count starts to rise, replace the drive.
