SOLVED SMART monitoring of Seagate Expansion USB drive
logan893
Is there a way to verify that the "behind the scenes", normally silent, SMART monitoring in FreeNAS is pulling data correctly?
I currently use 3 drives for data. Two 4TB in a mirror (da1, da2), and one 5TB USB drive for automatic ZFS snapshot backups (da4, using pools with copies=2 or 3 for single drive data redundancy).
The external USB drive is a Seagate Expansion Desktop 5TB (STEB5000200) with a Seagate Desktop 5TB (ST5000DM000) drive inside.
Trying to read SMART data from this external USB HDD without manually specifying device type fails. When supplying device type "-d sat" I can read the SMART data.
# smartctl -a /dev/da4
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/da4: Unknown USB bridge [0x0bc2:0x331a (0x909)]
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
# smartctl -a /dev/da4 -d sat
Model Family:     Seagate Desktop HDD.15
Device Model:     ST5000DM000-1FK178
Serial Number:    W4J17BJF
LU WWN Device Id: 5 000c50 0906af9ba
Firmware Version: CC49
User Capacity:    5,000,981,078,016 bytes [5.00 TB]
Rotation Rate:    5980 rpm
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Aug  9 16:05:19 2016 CEST
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
Warning: This result is based on an Attribute check.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
Self-test execution status:      ( 249) Self-test routine in progress...
                                        90% of test remaining.
data collection:                (  106) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 638) minutes.
Conveyance self-test routine
SCT capabilities:              (0x3035) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   119   100   006    Pre-fail  Always       -       222840768
  3 Spin_Up_Time            0x0003   093   092   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       28
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   072   060   030    Pre-fail  Always       -       4311974024
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       2345
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       12
183 Runtime_Bad_Block       0x0032   100   100   000    Old_age   Always       -       0
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0 0 0
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   052   051   045    Old_age   Always       -       48 (Min/Max 44/49)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       8
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       44
194 Temperature_Celsius     0x0022   048   049   000    Old_age   Always       -       48 (0 11 0 0 0)
195 Hardware_ECC_Recovered  0x001a   119   100   000    Old_age   Always       -       222840768
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       2343h+02m+46.344s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       7043245726
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       26771578346
SMART Error Log Version: 1
No Errors Logged
# 1  Extended offline    Self-test routine in progress 90%      2345         -
# 2  Short offline       Completed without error       00%      2344         -
# 3  Short offline       Completed without error       00%      2344         -
logan893
Update:
I checked the /var/log files, looking for SMART, and found that daemon.log has entries from smartd.
Most recent boot shows smartd "unable to autodetect device type", and furthermore unlike da1 and da2 there are no updates to attributes.
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da1 [SAT], found in smartd database: Seagate NAS HDD
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da1 [SAT], is SMART capable. Adding to "monitor" list.
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da2, type changed from 'scsi' to 'sat'
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da2 [SAT], opened
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da2 [SAT], ST4000VN000-1H4168, S/N:Z304SXZ1, WWN:5-000c50-086d6742f, FW:SC46, 4.00 TB
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da2 [SAT], found in smartd database: Seagate NAS HDD
/var/log/daemon.log.2.bz2-Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da2 [SAT], is SMART capable. Adding to "monitor" list.
/var/log/daemon.log.2.bz2:Jul 23 05:06:43 freenas smartd[2297]: Device: /dev/da4, unable to autodetect device type
In the drive volume status (Storage -> Volume Status -> Edit Disk), I found "S.M.A.R.T. extra options". Adding "-d sat" here seem to do the trick.
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], opened
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], ST5000DM000-1FK178, S/N:W4J17BJF, WWN:5-000c50-0906af9ba, FW:CC49, 5.00 TB
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], found in smartd database: Seagate Desktop HDD.15
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], not capable of SMART Health Status check
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], no ATA CHECK POWER STATUS support, ignoring -n Directive
Aug  9 16:30:27 freenas smartd[32120]: Device: /dev/da4 [SAT], is SMART capable. Adding to "monitor" list.
Aug  9 16:30:28 freenas smartd[32120]: Device: /dev/da4 [SAT], no ATA CHECK POWER STATUS support, ignoring -n Directive
Aug  9 16:30:28 freenas smartd[32120]: Device: /dev/da4 [SAT], is SMART capable. Adding to "monitor" list.
Aug  9 16:30:29 freenas smartd[32120]: Device: /dev/da4 [SAT], self-test in progress, 90% remaining
Can/should built-in support for this USB disk type be added to FreeNAS SMART monitoring?
nojohnny101
to my knowledge, USB drives do not support SMART knowledge and hence why they are not recommend to be used with FreeNAS.
