SMART ERROR short offline
bigfly
What does it mean ?
1、This SMART mean ?
2、CLI are not written to the configuration database and will be reset no reboot?
Dan Tudora
hello
1. this SMART report say "LifeTime" is 368 hours, and that is "LifeTime" of HDD (from start "born" until now), and is a verrrrry young HDD
BTW you make "burnin" procedure ?? like in https://github.com/Spearfoot/disk-burnin-and-testing
2. what you get is what you read. The "setting/change/fine tuning etc." MUST be make from GUI to remain "persistent" in config database
TrueNAS is a appliance over a FreeBSD OS
behind of that is a API/middleware/script and other thing who make check/validation of your configuration from GUI, ONLY FROM GUI !!
is a lot of work for do that with a few click of mouse from GUI
BUT IF you know enough about FreeBSD/TueNAS can do MINOR/IMPORTANT change/settings from CLI
you have been warned
Merry Chrismass
