Smart data - "Read Recovery Attempts"
ShimadaRiku
I have 6x8TB shucked WD white drives that are about 1 year old.
One of my drives has "Read Recovery Attempts" count that keeps growing about 20-25k a month. Currently it is at 296,436
Been watching the drive expecting it to have issues, but so far seems to be doing okay.
Googling around no one really talks about this error. Any info? Is this error count a concern long term?
ShimadaRiku
Just an update, currently it has grown to 1,777,974 but the drive still working in my NAS.
joeschmuck
Old Man
You do not provide any actual data. Please provide the entire output of smartctl -a /dev/your_drive if you are actually looing for some help. This will provide us the needed data. Also, provide the version of TrueNAS you are running.
ShimadaRiku
Been 3 yrs since my original post, but here is the current smartctl output
FreeBSD 12.2-RELEASE-p9 2ee62d665f0(HEAD) TRUENAS
        TrueNAS (c) 2009-2021, iXsystems, Inc.
        All rights reserved.
        TrueNAS code is released under the modified BSD license with some
        files copyrighted by (c) iXsystems, Inc.
        For more information, documentation, help or support, go here:
        http://truenas.com
Welcome to FreeNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@freenas:~ # smartctl -x /dev/da2
smartctl 7.2 2020-12-30 r5155 [FreeBSD 12.2-RELEASE-p9 amd64] (local build)
Model Family:     Western Digital Ultrastar He10/12
Device Model:     WDC WD80EZAZ-11TDBA0
Serial Number:    7SH2B95W
LU WWN Device Id: 5 000cca 252cf2aa7
Firmware Version: 83.H0A83
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Sep 29 17:06:33 2022 PDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (   93) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1061) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  --S---   129   129   054    -    112
  3 Spin_Up_Time            POS---   153   153   024    -    441 (Average 416)
  4 Start_Stop_Count        -O--C-   100   100   000    -    22
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         -O-R--   100   100   067    -    0
  8 Seek_Time_Performance   --S---   128   128   020    -    18
  9 Power_On_Hours          -O--C-   095   095   000    -    37170
 10 Spin_Retry_Count        -O--C-   100   100   060    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    22
 22 Helium_Level            PO---K   100   100   025    -    100
192 Power-Off_Retract_Count -O--CK   096   096   000    -    5842
193 Load_Cycle_Count        -O--C-   096   096   000    -    5842
194 Temperature_Celsius     -O----   185   185   000    -    35 (Min/Max 20/42)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   5501  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL,SL  R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     37152         -
# 2  Short offline       Completed without error       00%     37151         -
# 3  Short offline       Completed without error       00%     37150         -
# 4  Short offline       Completed without error       00%     37149         -
# 5  Short offline       Completed without error       00%     37148         -
# 6  Short offline       Completed without error       00%     37147         -
# 7  Short offline       Completed without error       00%     37146         -
# 8  Short offline       Completed without error       00%     37145         -
# 9  Short offline       Completed without error       00%     37144         -
#10  Short offline       Completed without error       00%     37143         -
#11  Short offline       Completed without error       00%     37142         -
#12  Short offline       Completed without error       00%     37141         -
#13  Short offline       Completed without error       00%     37140         -
#14  Short offline       Completed without error       00%     37139         -
#15  Short offline       Completed without error       00%     37138         -
#16  Short offline       Completed without error       00%     37137         -
#17  Short offline       Completed without error       00%     37136         -
#18  Short offline       Completed without error       00%     37135         -
#19  Short offline       Completed without error       00%     37134         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        Active (0)
Current Temperature:                    35 Celsius
Power Cycle Min/Max Temperature:     28/39 Celsius
Lifetime    Min/Max Temperature:     20/42 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (11)
Index    Estimated Time   Temperature Celsius
  12    2022-09-29 14:59    35  ****************
 ...    ..(126 skipped).    ..  ****************
  11    2022-09-29 17:06    35  ****************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              22  ---  Lifetime Power-On Resets
0x01  0x010  4           37170  ---  Power-on Hours
0x01  0x018  6    129454498853  ---  Logical Sectors Written
0x01  0x020  6       994297278  ---  Number of Write Commands
0x01  0x028  6    636776231236  ---  Logical Sectors Read
0x01  0x030  6      2557450393  ---  Number of Read Commands
0x01  0x038  6    133812101050  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           33984  ---  Spindle Motor Power-on Hours
0x03  0x010  4           33984  ---  Head Flying Hours
0x03  0x018  4            5842  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4         1760358  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              35  ---  Current Temperature
0x05  0x010  1              35  N--  Average Short Term Temperature
0x05  0x018  1              34  N--  Average Long Term Temperature
0x05  0x020  1              42  ---  Highest Temperature
0x05  0x028  1              20  ---  Lowest Temperature
0x05  0x030  1              41  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              39  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4               4  ---  Number of Hardware Resets
0x06  0x010  4              30  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            3  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            4  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
joeschmuck
Old Man
LOL, I didn't even notice that. I need to open my eyes.
Your hard drive performance is fantastic. Absolutely nothing wrong with it. Not a single actual error. And no Helium leak!
The values to look at to denote a pending drive failure is as follows for this drive:
SMART Attributes: 1, 5, 7, 22, 196, 197, 198, and 199 (199 is likely a data cable caused issue).
Normally I would not list ID 1 but your drive indicates the actual raw data to see, Seagate drives eh, don't in most cases.
