SMART daemon crashes when trying to read my SSD
Thomymaster
Hi guys
I have my FreeNAS running with 4 HDDs and one SSD as ZIL device. When i try to configure a SMART test and include my SSD (ada0), then the SMART daemon stops working (see screenshot attached), when i remove the SSD it works again. When i manually try "smartctl -a /dev/ada0" i get my SMART data.
What is the problem here?
Cheers
Thomy
joeschmuck
Old Man
Bet that when you run the test manually you don't have a TEMPERATURE value. this actually might be something worth looking into however I also realize you're new here but you need to provide the required minimum data so we can give you proper advice.
In order for us to help you with your question we will need the following information to the best of your ability. We do not like to make assumptions here as we might give wrong advice and the next thing you know, your data is gone forever. Please follow the forum rules so that we can offer proper assistance. Below is the rule #3. Provide as much information as possible and don't assume we know exactly how your system is configured.
Including the following information in your thread will increase the chance you will get an answer:
  1. FreeNAS version and platform (32 or 64 bit).
  2. General hardware information (CPU, RAM, Motherboard model, etc.).
  3. Specific hardware information (Network card chipset, Raid controller chipset, etc.).
  4. DMESG output or copy of specific error message.
  5. IFCONFIG output if you are asking about a NIC or networking problem.
  6. PCICONF -lv output if you are asking about MotherBoard and / or PCI card problems.
  7. Code snippets, logs, config files and quotes should be enclosed in the appropriate bbcode tags.
  8. To provide you with accurate answers we need this information and it will also help others to find your posts when they are searching for similar information.
[THIS IS A CANNED RESPONSE :p]
Thomymaster
Build FreeNAS-8.3.1-RELEASE-p2-x64 (r12686+b770da6_dirty)
Platform Intel(R) Xeon(R) CPU 3040 @ 1.86GHz
Memory 2031MB
HDDs: 4x Seagate Barracuda 7200.11 (ST31500341AS) configured as a RaidZ2 with "force 4K sector"
ZIL: none yet
L2ARC: 64GB SSD (Samsung PM800)
Mainboard: SuperMicro Z7DVL-E (all HDDs connected to internal S-ATA2 ports)
The error message i posted in the earlier post
joeschmuck
Old Man
Thanks for the quick response. First I'd tell you to remove the ZIL from your pool and then from your computer case. I have no idea what you are using this system for but your RAM is really too low and you need to bump it up to at least 6GB, but if you want great performance then just up to 16GB RAM as this allows high speed RAM to be the cache (LARC) and a ZIL just isn't really for most applications. This also goes for an L2ARC. I've done some testing and here is the link... http://forums.freenas.org/showthrea...Tek-NIC-Performance-Testing&p=58536#post58536 Don't let the name of the thread fool you, I have specific ZIL and L2ARC testing included.
I'm interested in the fact the SMART tests fail for the SSD. I'm sure FreeNAS has a bug which fails but I'd like to know more about how you are setting up the SMART test to be run for when you get the errors. Please assume I know nothing as it's the best way to give me all the information I might need to look into this.
Could you please post the results of the manual smartctl -a test for the SSD?
Thomymaster
[root@freenas] ~# smartctl -a /dev/ada4                                         smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p7 amd64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model:     SAMSUNG SSD PM830 mSATA 64GB
Serial Number:    S0XMNYAC201633
LU WWN Device Id: 5 002538 043584d30
Firmware Version: CXM12D1Q
User Capacity:    64,023,257,088 bytes [64.0 GB]
Sector Size:      512 bytes logical/physical
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4c
Local Time is:    Wed May  8 09:59:58 2013 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x02) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  300) seconds.
capabilities:                    (0x53) SMART execute Offline immediate.
                                        command.
                                        No Offline surface scan supported.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (   5) minutes.
SMART Attributes Data Structure revision number: 1
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   099   099   000    Old_age   Always       -       167
 12 Power_Cycle_Count       0x0032   099   099   000    Old_age   Always       -       26
175 Program_Fail_Count_Chip 0x0032   100   100   010    Old_age   Always       -       0
176 Erase_Fail_Count_Chip   0x0032   100   100   010    Old_age   Always       -       0
177 Wear_Leveling_Count     0x0013   099   099   010    Pre-fail  Always       -       3
178 Used_Rsvd_Blk_Cnt_Chip  0x0013   093   093   010    Pre-fail  Always       -       54
179 Used_Rsvd_Blk_Cnt_Tot   0x0013   094   094   010    Pre-fail  Always       -       96
180 Unused_Rsvd_Blk_Cnt_Tot 0x0013   094   094   010    Pre-fail  Always       -       1536
181 Program_Fail_Cnt_Total  0x0032   100   100   010    Old_age   Always       -       0
182 Erase_Fail_Count_Total  0x0032   100   100   010    Old_age   Always       -       0
183 Runtime_Bad_Block       0x0013   100   100   010    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
195 Hardware_ECC_Recovered  0x001a   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   253   253   000    Old_age   Always       -       0
232 Available_Reservd_Space 0x0013   093   093   000    Pre-fail  Always       -       762
241 Total_LBAs_Written      0x0032   099   099   000    Old_age   Always       -       151165166
242 Total_LBAs_Read         0x0032   099   099   000    Old_age   Always       -       3859318
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
paleoN
If you notice joeschmuck was correct. Not sure how flexible the GUI is with this, but maybe create a seperate test for the SSD without checking for temperature if possible.
Nevermind. Looking closer it's exiting on (no Directive -d removeable). What does your smartd.conf look like:
cat /usr/local/etc/smartd.conf
joeschmuck
Old Man
The FreeNAS system should still let a SMART Test be run so it looks like there is an error there. However again, the ZIL is likely not going to help you at all but if you leave it in, if the ZIL dies you will know it and you will not loose any data if it fails with a ZFS V28 formatted drive pool.
Thomymaster
Hi
I now changed the SSD to be the L2ARC instead of ZIL which makes more sence with ISCSI. Here isa my output of smartd.conf:
/dev/ada4 -n never -W 20,50,60 -m ***@***.de -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(3)/(13)
/dev/ada0 -n never -W 20,50,60 -m ***@***.de -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(3)/(13)
/dev/ada2 -n never -W 20,50,60 -m ***@***.de -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(3)/(13)
/dev/ada1 -n never -W 20,50,60 -m ***@***.de -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(3)/(13)
/dev/ada3 -n never -W 20,50,60 -m ***@***.de -s S/(01|02|03|04|05|06|07|08|09|10|11|12)/../(3)/(13)
/dev/ada4 is the SSD
Cheers
Thomy
titan_rw
If it's saying "unable to register device, no directive -d removable", I think that means it couldn't find the ssd at that time.
I'd be wondering exactly why, but you could try the following in "smart extra options" under "view disks - edit".
-a -W 0 -d removable
The -W 0 will get rid of the temperature warning. -a tells it to enable all the regular tests. The -d removable tell smart to run even if it can't open that particular device. Again, I'd be wondering why it can't open it at that time.
Also, why bother running self tests on an ssd? Do they actually do any good with flash media? Personally, I would disable them under "system - smart tests".
