Hazimil
 - May 26, 2014
I'm currently testing my new build and have successful run (with no errors) the following tests on all drives (ada0 to ada8)
However, I can only run the following test on my Micro SSD boot drive (ada8), and not the WD Reds:
If I try to run it on the WD reds I get the following error:
Am I doing something wrong, or is there a problem with the WD reds, or is it they just don't support that test (which is what I'm thinking)?
Any guidance, would be welcomed.
Yours
Jonathan
smartctl -t short /dev/ada0 smartctl -t long /dev/ada0
smartstl -t conveyance /dev/ada8
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION === Conveyance Self-test functions not supported Sending command: "Execute SMART Conveyance self-test routine immediately in off-line mode". Command "Execute SMART Conveyance self-test routine immediately in off-line mode" failed: Input/output error
Yours
Jonathan
