SM X10SL7 - BIOS 2.2 and IPMI 1.92
Sir.Robin
New BIOS and IPMI available :)
http://www.supermicro.com.tw/products/motherboard/Xeon/C220/X10SL7-F.cfm
Anyone done it?
Changelogs! :D
EDIT1: Sensor problem!
Can't read IPMI with ipmiutil anymore. Also the sesor readings were ghone in the IPMI web GUI.
Reset to factory defaults solved the GUI issue, but i still can't get IPMIUTIL to function at all.
EDIT2:
Ipmiutil is ok again. Had to use the default 623 RMCP port. :)
So only the sensor readings in GUI were a bug from the firmware update.
Saw a line somewhere in the increadible messy changelog (under some other version) that a factory reset should be done after flashing.
  • IPMI 192ReleaseNote.txt
  • X10SL7_ReleaseNote.txt
charlie89
download link is -> here.
But as usual no changelog... and i don't install any bios update without a changelog when my system runs rock solid :)
Also available for other X10 boards, including X10SLM+-F/X10SLL+-F/X10SLH-F/X10SLM+-LN4F
That said, I'll echo charlie89's statement.
Though Supermicro generally provides a chnagelog if you ask support nicely.
Sir.Robin
Well... new version means bugfixes. 1 year since last time.
I just updated both. No issues so far. :)
Sir.Robin
I did IPMI first. Then BIOS with the IPMI utility. :)
Sent from my mobile using Tapatalk
With a code or did they unlock that for everyone?
Sir.Robin
I got the code from earlier...
Sir.Robin
You can easily do it with a bootable CD. Use remote control... mount bootable ISO and boot into DOS.
Then with BIOS on the mounted ISO or on a USB stick... run the update utility.
Or you can get your license key from here:
http://www.supermicro.com/solutions/SMS_SUM.cfm
Yeah, I know. It's still a pain, though.
And I'm not going to pay them 30 bucks to provide incentive for this business practice.
Sir.Robin
errh.. you sign up for Evaluation Software and get the license key for free. and free is nice :D
TXAG26
I just updated both the IPMI firmware and the bios. Everything went smooth and seems stable.
For the bios update, I used Rufus to create a bootable USB drive, placed the bios update folder on the USB drive, enabled USB boot in bios and away it went after typing in the command & bios file name. I actually did all of this remotely using IPMI.
doublej0
I recently purchased a SM X10SL7-F board with 8 GB of ECC RAM and an Intel i3-4340 CPU. I purchased this combination of hardware because everything said it work with VT-d. I am looking to do ESXi virtualization and was having problems with the passthrough not working so I updated the bios to version 2.2 build date 3/24/2015. My problem is that VT-d shows "Unsupported" (see System Agent Configuration) with no method to change. I searched Google but have come across nothing that would suggest the options would not be Enabled/Disabled. The manual says I should be able to update this option. This is grayed out. The only other hardware in the system is a RocketRaid 2720 raid card (which I do not suspect should have ANY impact on anything). I have also included my CPU config bios screenshots in case that might help. Of note, VT-x is supported and Intel Virtualization Technology is enabled. Any help would be greatly appreciated.
i3s don't support VT-D. I think there is 1 or 2 exceptions, but they are basically $20 less than the E3-1230s and perform much slower than the Xeon. So I think your answer is "buy a Xeon".
Sir.Robin
Yup as the others already say.
Been running this board with vt-d since i bought it in 2013...
You either have really cheap Xeons or very expensive i3s. Around here, the Xeons are twice as expensive as the i3s.
doublej0
How did I miss that? Ugh. I swear I looked at the right thing. Nevertheless, thank you for the responses.
Sir.Robin
Anyone done it?
Changelogs! :D
EDIT2:
